need 77 vette motor info...
anyone know what the stock compression ratio was on the 77 corvettes and with what chamber head they where using to get that cr? i am trying to find out what my c.r. will be with a head swap but i dont even know what it is now....
need your help!!!
thanks in advance
jerry
need your help!!!
thanks in advance
jerry
thanks alot
but now i need to know which motor this is? block numbers tell me? what are the numbers of each as i have to go check the numbers on it if this is the case...
Originally Posted by AZSpeedBuggy
if your 5th digit of your VIN number is "L", then it has a L48 engine.
AZSpeedBuggy
AZSpeedBuggy
i know my motor/block was from a capric/impala..... i have a 77 also....
b
b
Originally Posted by ladystoy69
sounds like a ez way to tell but problem is motor is not in a car so i just know it is out of a 77 corvette, no longer have the vette around to get numbers off of
also on the passenger side -front of the head - there is a flat area that is on the block (sticks out form under the head) here you will find a number and a three letter code..
180 HP with Automatic transmission - California emission CHD / CLC
180 HP with Automatic transmission - High altitude CKD / CLB
180 HP with Manual transmission CKZ
180 HP with Automatic transmission CLA
210 HP with Manual transmission CLD
210 HP with Automatic transmission CLF
one of those three letter combinations should appear - if there is nothing, then its likely the motor has been decked and the codes removed.
