Quickest (Drag Strip ET) naturally aspired small block C3?
Is there anybody on the forum with a naturally aspired small block C3 (full frame car) that beats my best ET?? (11.05)
I know that there are a few big blocks and maybe some turbo/blown/nitrous small blocks..but I can't remember seeing any naturally asipred small block C3 that is that quick...
Is there anybody faster??
naturally aspired
a@#fire?
I have not seen any sbc c3 run that quick... if you go to a C5... yes I have! In person no less ! Ls1 with Heads Cam Stall Gears and slicks... run in the 11s like nothing... some to the 10s
Maybe a year from now when I can save more money for my vette fund. I may get there. not.
Originally Posted by holley505
Yeah I think that was a little red FORD...
a@#fire?
a@#fire?
Originally Posted by big632
Not a c3, my engine builders 355 small block nova is running 10.50s,single carb powerglide 4.88 gear 10 inch tire 2900lbs.
Originally Posted by LOTAHP
There is always somebody FASTER. The Forum is a very small community.
Oh by the way....You forgot to add "ON 93 OCTANE" Then I'll woop your BUTT !!!!!.
Originally Posted by GrandSportC3
I'm actually gonna try 93 octane in winter.. We will see how the car is going to run with 93.... It might just work fine considering that the big cam is going to bleed off some compression..so my dynamic compression ratio is not too bad..
Your timing will be soooo retarded it'll QUALIFY for the "Jerry Lewis Telethon"
I actually ran 11.38 with 50 degrees total timing..which was 14 degrees past the recommended 36 degrees.. I'd bet that I'll still run mid 11's on 93 octane...
Originally Posted by yellow73sb
i know a guy ran 10.50's back in the 80's before i was born
Originally Posted by Mr. Wonderful
I think you mean naturally aspirated
Originally Posted by Glensgages
..... maybe I'm showing my age (or quite-probably, my stupidity..... ), but " I " always thought 'naturally-aspirated' meant with a carb, WITHOUT any type of injection ( NO fuel-injection, turbo-charger, super-charger, etc. ), making all these newer-style EFI-cars NOT naturally-aspirated.....
Originally Posted by 69 N.O.X. RATT
You are right, you are showing your age N/A means no boost or other power adders i.e. nitrous. Fuel injection in N/A.
I need to take my Geritol and go to bed.....
Very few people actually race on the track. Even fewer race as their main hobbie. Many members have up their hp from where the factory shipped it. You know as well as anyone, once you get to a certain point it takes more the horsepower to run fast. I for one do not have any desire to run it the 10's, not even in the 11's. If I had time, money and an intrest, things maybe different. In the mean time, we'll watch your posts to see if you ever break 11.
Location: 406ci SB, AFR 180 Heads - 490 HP @5,600 RPM 529 lb-ft @ 4,100 RPM
As a X drag racer of 20 yrs,(and not a daily driver car) I would estimate that for every $1000.00 spent on my engines or supension. I would gain 10th second. So just do the math from a stock HP engine at 14 or 15 sec. run. But I never could put a cost on me sleepin at the tree made me come in second though with 2000 plus HP (not bad)
A tenth for a 10 second car probably costs at least twice as what it costs for a 14 second car...
