Why clocks don't work...
Old Aug 19, 2005 | 08:48 AM
1971Coupe's Avatar
1971Coupe
My clock works, It's accurate within 12 hours.
Old Aug 19, 2005 | 03:59 PM
Chuck Gongloff's Avatar
Chuck Gongloff
Active Streak: 90 Days
Originally Posted by JRS 73
What is the procedure for cleaning and oiling the clock?Mine doesn't work, and I am wondering if I can get a quick fix. Thanks.
It's been awhile, but after you take the clock out of the dash, and have it in your hand, remove the **** that sets the hands.
Turn the clock over...look on the back. You'll see several bent over tangs. Gently pry the tangs open. Then you can pull the back off the clock.
Clean the internals with a small paint brush...oil with "3 In 1 Oil", dress the points, and try it out.
If I remember correctly, most movements are Borg movements, and they're pretty stout. It's usually the electric rewind that fails. Chuck
Old Aug 19, 2005 | 04:09 PM
jackmoore's Avatar
jackmoore
Default 1 of the reasons vette clocks break is we time warp 2
much.
Old Aug 19, 2005 | 07:55 PM
SHAKERATTLEROLL's Avatar
SHAKERATTLEROLL
I have to agree on one thing if you want a watch that does keep time DO NOT purchase a ROLEX. The time adjust **** tends to pull out very easy which is another expensive fix and they also never ever keep good time. If you do have one that keeps time decent do not mess with it lol. And I mean not even a clean job or it will get messed up.
Old Aug 20, 2005 | 01:03 AM
codestar7's Avatar
codestar7
Default Time warp
Chuck has the right Idea, And you guys with the 3 minute incorect time mechanical works. Well If you can imagine 30 years ago, time just wasn't that important, like gas and cars and pretty much all other material posetions. Can you believe there was a time in the late 70's early 80's when C3's were concidered old sports cars and not worth much!
Old Aug 20, 2005 | 01:15 AM
Chuck Gongloff
I have to disagree with you on this one. I have two Rolex watches, and my wife has one. All three run perfectly, within a few seconds per day, which is incredible for a mechancial watch.
I like watches. I don't wear any jewelry, except my wedding ring. I don't wear bracelets, neck chains, college rings, etc. The only "jewelry" item I wear is a watch, and I like "neat" ones. Chuck
Old Aug 20, 2005 | 05:23 AM
SHAKERATTLEROLL
Chuck you are one of the lucky few.
