Need help with PCV hose on '77
My question: Does the PCV hose need to be connected to a vacuum source? If so, to where? either the front or rear manifold vacuum ports? (I have a Holley 750 vacuum secondary (4160). Right now I have my tranny vacuum connected to the front port, my distributor connected to the port on the right side (near the top just behind the front fuel bowl), and the power brake booster connected to the rear port. I've thought that the PCV is connected to the front port, but I'm a little confused about something. If indeed the PCV is connected to a vacuum source, for example if I was to "T" it in with the tranny vacuum at the front port, wouldn't there be a major vacuum drop since there's no real vacuum pull from under the valve cover? Wouldn't that affect the vacuum for the distributor, or whatever is connected with it there? Need some insight on this, and probably some advice on whether or not the distributor is connected to the right port - should it be connected to the front or rear port instead of the one on the side? Sorry for all the questions, but really kind of stuck here.
Thanks, Marc.
Thanks, Marc.
Originally Posted by fl_rider
With a quadrajet the big port on the front is full manifold vacuum.
I don't have a Holley though, so maybe someone else knows how many free vac sources there are on it.
