HP Rating for a L48 - 1975
#41
Originally Posted by glen242
Sears timing light - the clamp on plastic inductor for the #1 wire slipped down near the headers = melted inductor clamp. Replacement cable from Sears = $45.
Hooked it up and kept the inductor clamp up near the distributor. Clamp starting melting again! Now I know the 383 puts out more heat than the 350 but WTF? BTW, the engine runs 195* water temperature at idle.
I would recommend a dial back light with a metal inductor clamp. My old non-dial back has a metal clamp and I never had a problem. Guess I'll use it, along with the damper, which is marked out to 60*.
-dath
#43
Kalaway - You're right, at least it's a Vette You can easily get more power out of it, especially if you don't have to smog it where you live. Putting on headers and a free flowing dual exhaust would give you a good bump up, especially with a little tuning of your HEI unit and the carb.
-dath
-dath
#44
-dath
-dath
