yeah we sandblast our frames and paint them with por15 but what about the inside?
A lot of these cars I've seen that came from up north seem to rust from the inside out SO we you guys do a complete restoration and sandblast the frame what do you do about the inside of it to prevent rusting? I've been thinking about this and basically the only way to really cover it is to have it dipped...has anyone done this? any special places that do this or what?
just thinking about what route to go when I decide to do ours one day
The ORIGINAL and bestest
Toronto Events Coordinator
I used a modified garden sprayer to spray paint thinned down a little,inside of mine. It worked quite well. Then I spayed it full of a waxy rustproofing.
It was quite messy, but I had the luxury of working with a bare frame. I also tilted it around a few times while spraying the let the paint run into the cracks and crevices.
I'll be working in a small area, body maybe 1-2 ft. above the frame. Should I shield everything with drapes around the car? My wife is a sug. tech and gets these drape that nothing will pass through, if I suround the car (bottom, sides) is that enough.
eastwood sells undercoating sprayers that are long tubes and have directional sprayers. that may give you a little more control. thinned dwon POR worked well on the inside of the frame. Of course the body was off. It did run out all over but that is what i wanted.
Thats a good tip. Im doing the same thing to my frame (one day ! not right now though)...and definitly using POR inside and out of the frame.
