I just finished this 68 shifter plate. It turned out pretty good. It's amazing what a good cleaning, some paint, a new heater control lens and rubber boot will do.
Outstanding job.
Please elaborate on how you did it, what type paint and manufacturer, what was the prep work.
How did you replace the lens for the heater control?
I have new lens and would like to try it.
Thank you,
Kurt
Tony, what paint did you use? Satin?
How did you get the 'chrome' to show after spraying it...
Really, explain what/how you did it...
Thanks.
The 1st thing I do is take the heater control, boot and ash tray housing off the plate. Then I spray the ash tray door and plate with carb cleaner. That gets all the gunk off and any loose paint. A good cleaning with soap and water after that. This is important! The plate MUST be clean before you paint it. I run some pin stripe tape around the outer chrome edge. As for the inner chrome edges and words, they get painted over. They are just to thin to tape off. Blue painters tape over the “cross flags” and trim with a SHARP hobby knife. 2 light coats of flat black spray paint. Then 3 light coats of satin black spray paint. Don’t try to do it in 1 coat. It looks like crap. Take your time with the coats. Let it dry 1 full day. Scrap the paint off the chrome edges and letters with the hobby knife. Yes it takes some time, but it’s the only way I found that works and looks original. This takes some practice, but after doing about 20 of these it seems easy to me. The cross flags I paint with a tooth pick and model paint. I do the red and white. Let it dry for a day and scrap the chrome edges with the hobby knife. After that I do the black on the flag. Same thing. Let dry for a day and scrape the chrome edges. Take your time and use some cheap magnifying glasses if that helps. I hope this helps anyone trying to do it your self. Just remember. If you don’t like the way it turns out. Just clean it and start over on it. It’s just paint.
