Tech/perf isn't exclusive.... or it don't work.
I noticed some posts that shouldn't be moved are and others that should be aren't
I'm thinking it would be simpler just to call it ENGINE.
OR
It might be or probably is that no one sees these heading use directions. They don't show up on the forum when your on it only under the general tree. I for one don't link to that but straight to Tech. You don't see any of the items its meant for before you post or while you read the listing.
My reasoning here is I did a check on the other forums, to see how well this works on the other sides and it don't work there either.
Anyway at the very least look at what the moderators have to deal with. Some are easy others aren't I skipped the definite and dubious. Only listing those which seemed out of place. Some of these might be tech since I didn't read them.
I'm not sure, as apparently many, whether handling is a tech item or not? Wheels suspension and the like. IT does fall under tech topics?
Definition for the tech forum is
Internal Engine | External Engine | Tech Topics | Performance Results
Maybe tech topics should be taken out since thats kind of general, if anyone is bothering to read it.
C6
Reverse switch adjustment
WS6 17" wheel on a Z51
Short throw shifter ( 1 2 )
C6 Tuning in Illinois??????
C6 Fuel Gauges
Drone
Turning noise
Can anyone confirm Z06 brake part numbers?
Caliper Powder Coating
To move on
C5
Code 1232 C ; Service Abs, Service Ah; What's The Fix?
Check Engine Light
Oil Pressure Sensor ( 1 2 )
C6 Z06 brakes on a C5 PART II (installation pics) ( 1 2 3 ... Last Page )
$500.00 Blue Leather Corvette Racer Jacket Give Away! Check In Now!!!
Air bag Switch "kit" ?
How to remove C5 Dash Board?
stop
C4 These guys either are having a good day or know how to use it.
To many repairs, Think I have to sell my 94! ( 1 2 )
Wet passenger side carpet – starts at the back first.
Hatch Release and trunk release related??
C3
Moved: recommendations for wheel/tire size on a 75?
Hood height
Hood Latches
how much "play" in steering
78 fuel Tank
schematics
cat converter test pipe in New York State
Alternator/charging problems
Moved: Laying New Carpet..NEW member
Headlamp Doors
Speedi Sleeve size needed
C1/C2
Dont have a tech section.
OR
C6
C6 Fuel Gauges
Drone
Turning noise
To move on
C5
Check Engine Light
stop
C3
Hood height
Hood Latches
78 fuel Tank
schematics
Headlamp Doors
C1/C2
Your thoughts are correct, but with an endless trail of newbies,
training is an ongoing and endless task.
I mainly read and post in Gen ... can't be bothered with split discussion forums.
Maybe I should save up and get a C2.
Also, tough to compare to C6, etc. I mean, how "tech" can you get
about a brand new car with the numbers it has off the assembly line.
Powder coating brake calipers ? I'd bet only 1% of C6 owners ever even
think about this ... never mind actually doing it. This would be C6 HI TECH.
You can almost count on someone bringing up this topic every couple of months..... The problem is that it doesn't change a thing, kind of like changing politicians every couple of years.
1 Post
Originally Posted by Desertdawg
Thats it, enough of this madness, It's time to combine the 2 sections in C3...
Who's going to start the poll?????
Guess I am like the Borg, I was assimilated to the split section single mind
