Brakes Were Fine When I Parked It, Then . . .
got in it the next morning and didn't have any. Well, almost none. Just enough to stop while going slow. Brake pedal is very hard, no spring in it at all. Fluid resevoir is OK. I don't see brake fluid on the wheels or on the floor of the garage. What's up with this? It's a '75 coupe.
If all is good I would susspest that the diaphram in the booster is at fault. Does the engine run correctly? if so susspect that the master cylander is at fault. (rule number one when trouble shooting= always check the cheapest part to replace or manufacture first) Good luck
