interior Paint
interior Paint
I'm about to paint my interior, any tips, knacks or suggestions before I get started. center console and gauge area concern me the most, by the way it's a 1971 corvette.
Cleaning is the key to a good dye job. Use denatured alcohol, degreaser, or anything that doesn't leave a film behind. Just when you think it's clean....clean again.
Several light coats of dye works best.
Eddie
Eddie
Eddie
Eddie
Location: THE OLDER I GET THE BETTER I WAS! NORTHERN ONTARIO
Eddie
Eddie
Worked for me
Originally Posted by kevin1979
After you die everything, how do you get the chrome trim around everything? Q-tip and model paint??? I think I might take mine off and try that this winter.
Eddie
Eddie
Eddie
I haven't had much luck redying stuff. The last piece I did was starting to turn out good. Many, many thin coats of dye. (I was painting red over black). This was the trim piece that fits between the T-tops. Then I accidentally hit the trip piece with a screw driver handle. A square inch piece of red paint fell off. Argggh.
St. Jude Donor '10
i am about to gut my interior and change to doeskin from red... people have told me that everthing must be well cleaned.. not dying much just seat frames ,steering column and a few small pieces...........good luck
1 Post
What color is it now, and to what color are you changing it?
If you get the chance take some before and after pics and post em. I've always been curious to see how this stuff really works.
As several people have mentioned already cleaning is key. Used a cleaner / degreaser I got from a local auto parts shop which worked uite well. Washed everything with soap / water, then the cleaner several times, then several coats of paint. One some of theparts I went too heavy with the coats so initially looked a little dull. Ended up using a clear gloss over top and now looks great...Someday I will finiish the rest of the pieces.
Shane
Shane
http://forums.corvetteforum.com/show...n&forum_id=119
The ORIGINAL and bestest
Toronto Events Coordinator
You will find this stuff at the suppliers that cater to the auto body shops, or you can order it online.
http://shop.store.yahoo.com/yourauto...vinylprep.html
As for painting the center consol and gauge cluster, I find that Krylon semi-gloss black looks the best, and you can tape off the chrome areas with very thin masking tape.
Here is a pic of my dyed vinyl and plastic pieces, and painted metal pieces:
Eddie
Eddie
