Proverbial Windshield Wiper Problem
Where is this relay I see in schematics and what is its function????
As far as what happens when you flip the switch, there is a good explanation in the shop manual. Basically the motor has 12v when the ignition is on, the wiper door is open (electrical switch on firewall), and the override electrical switch under the column is closed. It has 12v to the washer relay(internal to the wiper motor) with ignition on. When you push in the washer you supply ground to that washer relay. When you go to low speed you supply ground to the unpark circuit and the low motor speed. When you go to high, you also get ground to the high speed circuit. In low or high you supply ground to the wiper (electric over vacuum) relay screwed to the tach which supplies vacuum to the (vacuum over vacuum) door relay underhood. A good ground to the switch is essential.
