Who running a rear swap bar?
I have bilstein shocks w/stock fr & rr springs I was thinking of an upgrade to new stiffer fr & rr springs and mid-america & eckler have a setup w/fr coil & steel rear and a front & rear swap bar. I wasn't thinking of adding a rr swap bar? Would I even notice the difference? Is it an easy install?
OH it is Christmas eve so Merry Christmas to all.
Jim
Jim
Rear sway bar is easy to install....still running one on my 69...(I removed the sway bar on my 78 as rear end was to tight with the set up I had at the time...)
You may have to drill two mounting holes thru top of your trailing arm....not sure if GM provided those holes for non-FE7 vettes,though...
Rich
Rich
Originally Posted by rihwoods
... You may have to drill two mounting holes thru top of your trailing arm....not sure if GM provided those holes for non-FE7 vettes,though...Rich
Originally Posted by Jason Staley
The holes were on my 76 with a standard suspension. As to the question of the rear sway bar, .... keep it small ~5/8" or so. Too much rear sway bar will cause your car to be overly sensitive and oversteer ... spun my 76 due to a large rear bar. Now I don't have one at all, but am thinking about reinstalling a 9/16 or 5/8 on it this summer to get rid of a mild understeer problem.
Rich
