Vintage "bullet" racing mirrors
Old 01-21-2006, 02:34 AM
Zimo
Zimo's Avatar
Default Vintage "bullet" racing mirrors
Does anyone have any photos of this type of mirror on an early C-3?
I'm getting tired of my original driver side mirror losing it's adjustment at 70 mph. These vintage racing mirrors look too cool. Didn't they put these on the old L-88 race cars? I'd like to make it work with the factory mount.
Original mount
Mount on bullet mirror
Old 01-21-2006, 06:28 AM
Jason Staley
Jason Staley's Avatar
Cruise-In III Veteran
No, but I've always thought that those mirrors would be cool on a C3. Almost went that route last time with mine, but ended up going with the stock style one last time. Hopefully somebody has done this mod.
Old 01-21-2006, 09:02 AM
sdonnelly
sdonnelly's Avatar
I believe those are the same mirrors that came with most Bradley GT kits. Those same ones are on my sons and most of the others I see.
Old 01-21-2006, 09:09 AM
Jims79
Jims79's Avatar
I had them on the front of my 68 MGB, they were very popular on MBB-GT, TR6, TR4 & the GT model
Old 01-21-2006, 11:19 AM
Mako72
Mako72's Avatar
2018 C3 of Year Finalist
You might consider installing the mirrors that were installed on later year C3s (starting in 78?). My only concern with the ones you are considering is do they stick out far enough to allow you to see past the rear quarter fender peak. You may only need a new rear mirror as it sound like the ball joint may be worn. Mine will stay put up to a 100 or so.
Old 01-21-2006, 05:41 PM
I'm Batman
Support Corvetteforum!
I'm Batman's Avatar
St. Jude Donor '07
Go to "advanced search" and select searching in the active threads and archives. Tons and tons of threads on mirrors.
Old 01-21-2006, 07:10 PM
Zimo
Zimo's Avatar
Yeah, lots of threads on mirrors, but nothing on this type. I think I'll just get one to see if it will work or not. If not, it's going on ebay
Old 01-21-2006, 07:58 PM
I'm Batman
I'm Batman's Avatar
St. Jude Donor '07
Those mirrors are cool, I was just trying to point out all the options.
Old 01-22-2006, 03:51 PM
gbak
gbak's Avatar
I also got tired of the left mirror, I glued it, but it didn't help.
So I bought those on Ebay for $40.
It was not funny to mount them on the doors.
Took me three nights.
Had to loosen the windows and drill from inside for the studs/nuts.
You don't see so much in them but I like them.
Old 01-26-2006, 10:26 PM
cosmicvette
cosmicvette's Avatar
You probably do just need a replacement original side mirror to fix this problem but I would also like to see these mirrors installed on a C3, and if you can actually see anything in them due to the "hips" on the C3.
Old 01-27-2006, 09:21 AM
Zimo
Zimo's Avatar
I'm going to get that mirror along with a factory replacement mirror. I'm gonna try to make the bullet mirror work with the original mount & hardware.
Old 08-26-2018, 02:56 AM
falkenberg
Cruising
falkenberg's Avatar
Hi
I am considering the bullet mirror on my C3. Did it work for you and if so, how does it look? Regards Boe
Old 08-26-2018, 03:01 AM
cv67
cv67's Avatar
Received 3,043 Likes on 2,602 Posts
St. Jude Donor '05
Lots of cars back then used them. Believe the 70s camaros did also
Old 08-26-2018, 05:26 AM
NONN37
NONN37's Avatar
old thread.
Old 08-26-2018, 05:33 PM
The13Bats
The13Bats's Avatar
My 66 had them my 69 had one but its off right now,
Ac cobras and gt 40s ran them, lots of non usa cars did.
While they all sort of look the same, they mount differently, some from inside some from out some the base is mounted then the stalk mounts to it,
Some ive had come apart and likely could be used on the stock stalk, actually not a bad idea,
When this subject popped up in the other tread i found these,
mirrors
the stalk is super sweet to me, but these are plastic and i like the chrome look,
To Vintage "bullet" racing mirrors
Quick Reply: Vintage "bullet" racing mirrors
