Will GM mexican blocks accept straight bolt pattern starters?
Originally Posted by Yellow73SB
I bought mine at discount for like 30 dollars.
discount auto parts. I had to turn in a core though.
i went to their site. Had to look up like a 96 surburban to find the same one i have. Listed at $184.25 plus a $45 core. Hard to believe you can get that starter for 30 bucks. Maybe in a junk yard.
What did you look up your starter under. Was it a 73 vette?
St. Jude Donor '07
Yours might be different. I always look up parts under susburbans.
http://www.partsamerica.com/ProductL...tarter&ptset=A
I have a zz4 block I don't know if that is amde in mexico.
I am probally wrong.
Originally Posted by 68/70Vette
My ZZ4 block was henchoed in Mexico. I bought the ministarter recommeded for it. The ministarter had two pairs of holes drilled into the mounting block (or the ministarter). One pair was for the small diameter flywheel and the other for the larger diameter flywheel.
well i got it on and it works. The sound is a lot different which i don't know if i like. It sounds like a new car starting being much quieter. Doesn't have that nasty mucle car starting sound anymore.
I'm gonna keep it though because it saves 10 pounds.
