Will GM mexican blocks accept straight bolt pattern starters?
I have the GM standard aftermarket block (el hencho in mehico). Does anybody know if it is drilled for both the staggered starter and straight bolt pattern starter. I have a starter from an L98 corvette and wanted to put it on.
I must be missing something here. You have the block and the starter correct? Why don't you see if you can bolt the starter to the block?
I don't know, maybe it's not that easy.
Oh well.
BigBlockk
Later.....
Oh well.
BigBlockk
Later.....
Oh well.
BigBlockk
Later.....
Oh well.
BigBlockk
Later.....
No. Will not work. You have to have a Mexican starter, too...
Oh well.
BigBlockk
Later.....
Oh well.
BigBlockk
Later.....
ltlevil
ltlevil
My Huevos Rancheros block..
has both straight and offset holes.
Offset is for use with the 168 tooth flywheel.
Straight is for use with the 153 tooth flywheel.
They are not interchangeable.
Ole' !!
Ole' !!
Different starters for different flywheels. Block does not matter. The L98 starter is for the small flywheel (153 tooth). I am using a late model BB starter with my 168 tooth flywheel. Works great.
Some of the aftermarket starters have the straight pattern with 2 sets of holes drilled so the starter will work on the large as well as small flywheels.
Somebody said here before that the newer vette starters would work.
My ZZ4 block was henchoed in Mexico. I bought the ministarter recommeded for it. The ministarter had two pairs of holes drilled into the mounting block (or the ministarter). One pair was for the small diameter flywheel and the other for the larger diameter flywheel.
turtle-were you just asking a general question or is there a specific reason you want to use that starter you have?
ltlevil
Location: Las Vegas - Just stop perpetuating myths please.
They are not interchangeable.Ole' !!
turtlevette u can look in my signature link to see my starter delema.
cardo0
ltlevil
ltlevil
Then i thought i saw a thread sometime back where somebody used a late model vette starter as a bolt on instead of an aftermarket ministarter.
But i'm glad i gave everybody a chance to rail on me for a bit. Payback is a bitch.
ltlevil
St. Jude Donor '07
And a Mexican Radio!
If you want a gear-reduction mini-starter for a 168-tooth flywheel, get the GM BB502 starter. Not cheap, but it works great. Not sure why more people haven't figured it out.
Originally Posted by I'm Batman
Not cheap,.
here is the thread that mislead me.
http://forums.corvetteforum.com/show...ht=L98+starter
I checked out what Autozone had and settled for this one at $129. Lifetime warranty and came with 2 bolts that they charge 10 bucks for on the alterstart site. Add 10-15 dollars shipping and its about a wash. You have the added convience of being able to run 10min down the road to Autozone and swap a bad one out.
St. Jude Donor '07
