Body Work Help...
Body Work Help...
I am about ready to take the body to get media blasted and start the body work and I came upon this problem. My convertible deck lid is seperating from itself at the drivers side. The top and bottom on the drivers side edge is coming apart from one another. What would you do to fix this problem?
I plan on having the body work done but want to have an idea of what im looking at when I go to the body shop. I also want to know what to tell the body man that I want done to correctly fix the problem.
Thanks for any help you guys and gals can offer! Here are some pics of the problem.
Thank you for your help! Will anything else need to be done to smooth the edges or would you just let it go like that once they are sealed together?
Thank you again for posting!
I heard sand blasting was a major no no but I thought other media that was softer could be used without much thought. Ill have to re think my plans if this isnt the case.
Thanks!
Thanks!
Thanks!
Thanks!
I had some areas on my 81 that looked like that around the dog leg of the quarter panel, bottoms and fronts of front fenders. I tugged on them and to my suprise, the panels came free even beyond where the seam was cracked. The panels didn't come all the way off, obviously, but where the seams were cracked, the joint must have been pretty weak. I spread the gap as much as I could with a screwdriver, blew it out and worked some folded 80 grit sandpaper up and down the seams so the new adhesive would have something to "bite" to. I opened the gap at the seam and squirted some new adhesive in there and clamped it down. I used the 2-part stuff by duramix.
Mark G
Mark G
