What is the equivalent of a G 70 15 (20570r15)? I'm looking for the largest tire that will fit in the spare tire carrier. I have 255 60 r15's on the car (73 coupe) and they wont fit. This tire probably will never be mounted on the car unless the unthinkable happens.
How about one of those temporary spares on an aluminum rim that many GM's had?Very lightweight and should fit in the tub,just need to find one with close to same circumference as the tires you want to run.
I pulled a 225/70 out of my rear tub.. didnt have a rim with it, was just a tire
I think thats as big as you can go
Keep in mind that on a rim w/air the tire will expand. I have a 225/60/15 mounted in my spare tub fits fine. The 225/70/15 may fit.
I would try it out before you buy a tire & rim
2024 C3 of the Year Finalist - Unmodified
