Clear Coat Scratch Removal
Old Apr 5, 2006 | 11:03 AM
Higs's Avatar
Higs
Default Clear Coat Scratch Removal
I have a few very fine scratches in the clear coat that normal waxing does not remove. Anyone know what to use to remove? Thanks
Old Apr 5, 2006 | 11:41 AM
corvgreg's Avatar
corvgreg
Emerging Vendor
Try polishing compound, if not enough then rubbing compound, if not enough then wet sand with 2000.
Old Apr 5, 2006 | 12:14 PM
crazywelder's Avatar
crazywelder
I'm trying to think of readilly available products. Meiguars Fine Cut Cleaner will remove the scratches, but will leave some haze. Follow that with some Meiguars Machine Glaze (by hand), until the haze is gone then use your wax.
Old Apr 5, 2006 | 12:29 PM
Rich_71Vette's Avatar
Rich_71Vette
Go to the Car Care section of the forum and search for Menzerna or MIP. There are a lot of before and after pictures. This stuff looks great and has been highly recommended there. I ordered the polish and plan to do the car next weekend.
Old Apr 5, 2006 | 01:03 PM
crazywelder
I've used Meguiars for over 30 years, but I'm going to try some of this German stuff. After visiting the web site I see in their comparison chart that they have fewer abrasive cuts than Meguiars and 3M so I just wonder if it's really that much better, or is it designed to be easier for retail consumer use by taking out the confusion caused by having multiple products. With Meguiars or 3M you need to know each specific product and not all of them are sold at retail stores.
Old Apr 5, 2006 | 02:04 PM
ajstr1265's Avatar
ajstr1265
Use a fine polising compound then polish and wax. I have heard there is a zaino product for this but I don't know much about it.
Old Apr 5, 2006 | 08:22 PM
carl a's Avatar
carl a
buff it out. buffing compound and a buffer. you can get a buffer from harbor freight under 40.00!!i bought one and its good enough for a weekend warrior,,chicago electric,made from our good friends in china
Old Apr 5, 2006 | 10:20 PM
Higs's Avatar
Higs
I have an orbital buffer but I don't want to make things worse. I just don't want to have that moment when I say sh@t why did I mess with it in the first place.
By the way, I am from Houston Texas.
3joh's Avatar
3joh
3M Finesse it II on a rotary buffer with a charcoal (very soft) colored pad. This is what I use on black cars all the time. Black cars seem to be my specialty. Then follow up with a good wax. Maybe practice on the DD first.
Old Apr 5, 2006 | 10:34 PM
bondoboy's Avatar
bondoboy
An orbital buffer will not do much. You need to use a rotary buffer.
Old Apr 5, 2006 | 11:21 PM
Sacredgrooves's Avatar
Sacredgrooves
I use mainly zaino...and zaino fusion works real well for very light scratches...but, when my cats got on my car(who are lucky to even be alive now) I used menzerna intensive polish followed by their final product (fp2 I think it is called) and it took out all of the evidence of cat claws sliding around on a very well waxed car.
Old Apr 6, 2006 | 04:12 AM
hunt4cleanair's Avatar
hunt4cleanair
I was the same thing because I've got an dual action orbital buffer but its low rpm.
Explain what a rotary buffer will do that an orbital won't.
Old Apr 6, 2006 | 06:38 AM
crazywelder
A rotary buffer would be used for heavier work such polishing new paint after wet sanding, or reconditioning an older paint job, cuts fast, good for production work but not ideal for a couple of fine scratches. An variable speed orbital buffer such as a Porter Cable is ideal for light work such as fine scratches or polishing paint that is in good condition. Using the correct sequence of polishes with the orbital machine will give show quality results and minimal swirl marks. The rotary machine will leave swirl marks. However, using either machine requires a certain skill level and practice to obtain optimal results.
Old Apr 6, 2006 | 07:54 AM
Higs's Avatar
Higs
Looks like I will be taking it to a professional for this job. I have spent too much time grinding welds and not enough time polishing cars. It's funny you mentioned cats because that's why the cover goes on every time. Thanks
PS> Where do you get Menzerna?
Old Apr 6, 2006 | 08:15 AM
kaamacat's Avatar
kaamacat
If the scratches are similar to as if someone ran across it with a dirty towel...etc......... 3M's FinesseIt-II or III will make it look like glass. If its a bit more than that you may need to use some 1500paper (wet with a very small amount of dishsoap in it)........ then try the 3M product.
Its best used with an orbital polisher, or, a good random orbit with thick foam pad (like Porter Cable's #7424) is about the best you can find. Then apply your favorite wax.
The 3M-FII is actually a super fine finish polish, but you really cant feel the abrasive and is much safer than a "compound".
Old Apr 6, 2006 | 08:26 AM
vettfixr's Avatar
vettfixr
Check out my write-up on Reviving Old Paint.
http://mywebpages.comcast.net/vettfixr/page5.htm
Old Apr 6, 2006 | 12:20 PM
murvette's Avatar
murvette
Great website ,good info .....thanks
To Clear Coat Scratch Removal
