Pics of my 1969 Stingray
Old 05-25-2012, 05:23 PM
  #241
76stingraylover
76stingraylover's Avatar
Why not use flex line?
Old 05-29-2012, 11:35 AM
  #242
BOSTONCAMARO
BOSTONCAMARO's Avatar
I bent up a new line, better than the first, will do for now
Old 05-29-2012, 11:36 AM
  #243
BOSTONCAMARO
Old 05-29-2012, 12:13 PM
  #244
76stingraylover
looks good man
Old 05-30-2012, 09:39 AM
  #245
BOSTONCAMARO
Vapor line hooked up, going to tweak them a little more but looks decent
Old 05-30-2012, 11:22 AM
  #246
Ironcross
Ironcross's Avatar
simple line made with a 3/8 tube bender and a 3 way compression union makes a easy on and off
Old 05-30-2012, 03:26 PM
  #247
BOSTONCAMARO
Ironcross, your car looks great! I was going for an original-esque type of look, which is why I used original style filter, in its stock location way up in air haha.
I may even get redline tires, not sure yet...thanks for posting pics of your car, I like your fuel line set up...
Old 06-22-2012, 11:40 AM
  #248
BOSTONCAMARO
Boring stuff, but almost ready to fire it up.
Old 06-22-2012, 11:42 AM
  #249
BOSTONCAMARO
New ground wire for starter
Ground for MSD
Old 07-11-2012, 11:01 PM
  #250
BOSTONCAMARO
so I have been working on the car, put the braided oil line in, ran MSD wires and other stuff, then tonight, even though I had a very dear battery, hooked up jumpers, clicked key and it started to turn over!
next week, I will fix up the battery terminals, wires, buy a battery for it...
this weekend, after 30 years of wanting one, my dad bought his sweet 16 Donzi! so we are putting that in the lake up at the cottage...cant wait!
Old 08-06-2012, 11:17 PM
  #251
BOSTONCAMARO
Fixed battery cables, new ends, fixed battery compartment, charged battery.
Car didnt start, checked all wiring, didnt appear to have spark, swapped distributor for the hell of it still no spark, checked all wires...viola...MSD trigger wire, though the plastic plug were together, it was barely together, must have got pulled out...plugged in, turned key...started right up!!!
Small fuel leak on the line that I bought for the carb, took apart, liquid teflon, reseated, tightened lines, no leak!
Water leak from t stat housing, I looked close, micro pin hole from rotting alum...had several others, sandblasted, refinished installed put water in, started right up again, only ran for a few seconds.
Tomorrow night, top off fluid in trans, also noticed just a couple small drips from side of pan, need to investigate that, but the car sounds great, onto the brakes next.
I ran this motor in a 12 second street Camaro 15 years ago, so was nice to hear it start and run once again, the nicely built swap meet carb Chuck Nuytten carb ran just as described!
Old 08-07-2012, 09:59 AM
  #252
BOSTONCAMARO
oh yeah, did I mention my Corvette is running???????????
weeeeeeeeeeeeeeeeeeeee!!!!!!!!!!!!!!!!!
Old 08-07-2012, 11:11 AM
  #253
gbarmore
gbarmore's Avatar
To say that I am jealous would be a vast understatement, I cannot wait to hear my car start again for the first time! Nice work, good luck with the punch list, I know mine will be long since I took the car completely apart bolt by bolt, rivet by rivet. Long way to go to get where you are but making progress week by week. Keep the updates coming!
Old 08-07-2012, 11:15 AM
  #254
BOSTONCAMARO
I am glad I didnt take the Corvette apart like I did to my Camaro, it would be nice, but am looking forward to getting it on the road...too many projects to look at in the barn, need to drive something, also we just got my dads 68 Camaro running, pretty psyched about that too.
Old 08-07-2012, 09:44 PM
  #255
BOSTONCAMARO
It wasnt an oil leak, saw the leak tonight, it was from the rear of the power steering pump on the feed line, the fluid was coming out then running down the side of the motor, right along the edge of the oil pan. I am going to pull the pump tomorrow night, put new O ring in etc.
Tonight I topped off the transmission, ran it for awhile, sounds pretty good, need to run wire for the one wire alternator, run the MSD power wire neatly etc, but it is coming along.
Old 08-14-2012, 10:01 AM
  #256
BOSTONCAMARO
Power steering pump is pulled, got new replacement that had TONS of play in front shaft, waiting for the replacement of that to come in.
Got all the linkage parts from Corvette Central, fit perfect...I had a return spring already
Old 08-14-2012, 10:02 AM
  #257
BOSTONCAMARO
To Pics of my 1969 Stingray
Old 08-14-2012, 10:04 AM
  #258
BOSTONCAMARO
Old 08-21-2012, 11:42 AM
  #259
BOSTONCAMARO
new pump in place
Old 10-17-2012, 04:30 PM
  #260
BOSTONCAMARO
About to start on brakes and had to take a step back and realize progress has been made...
what I started with, pretty much stripped engine compartment, no brackets, wiring all effd up
Quick Reply: Pics of my 1969 Stingray
