still got air
Old May 31, 2006 | 11:13 AM
cab's Avatar
cab
Default still got air
i still have hot air blowing thru the vents on each side of the center console. the heater core is bypassed. where is this coming from?
Old May 31, 2006 | 11:53 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
What year? On some models, the fan stays on low all the time to assist with ventilation. If memory serves, you can disconnect the brown wire from the back of the fan switch.
Old May 31, 2006 | 12:10 PM
cab's Avatar
cab
my bad its a 77.
Old May 31, 2006 | 12:41 PM
SIXFOOTER's Avatar
SIXFOOTER
GM did that to discourage mold growth in the duct work, the air blowin thru there dries out the moisture
Old May 31, 2006 | 01:08 PM
cab's Avatar
cab
well thats no good because it is drying me out to.
Old May 31, 2006 | 01:38 PM
vettfixr's Avatar
vettfixr
More than likely this is your problem. It's a great fix and everyone I talked to that has tried it has been sucessful.
https://www.corvetteforum.com/techti...=241&TopicID=3
To still got air
