Question on air conditioning?
Old Jun 6, 2006 | 11:59 AM
rudolph schenker's Avatar
rudolph schenker
Default Question on air conditioning?
I have a 1982, the air conditioning has been redone and blows nice and cold from the lower vents, but does not blow at all from the ones above the gauges in the center? Any ideas?
Old Jun 6, 2006 | 12:29 PM
tyancey00's Avatar
tyancey00
If you have had the radio out or anything else in that area I would check the duct work. I replaced the radio on my 80 and had to play with it to get the ducts back where they belong.
Old Jun 6, 2006 | 12:33 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
You're probably keeping your center gauges nice and cold.
Old Jun 6, 2006 | 01:36 PM
gq82's Avatar
gq82
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Vacuum line is disconnected....do you hear a hissing sound coming from the controls or anywhere else.....it's most likely your problem.
Old Jun 6, 2006 | 01:43 PM
rudolph schenker
Yes there is a constant hiss from the controls. I'll check the vacuum lines! Thank you!
Old Jun 6, 2006 | 02:03 PM
Lon Wayne's Avatar
Lon Wayne
Default lon wayne
Seems so simple, that vent on my 75 has a shut -off is yours just shut -off?
Old Jun 6, 2006 | 02:30 PM
rudolph schenker
Don't want to appear too dumb,,, how do you shut the vent off?
Old Jun 6, 2006 | 02:35 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
It's vacuum operated. The hissing you are hearing is almost certainly the vacuum line you're missing. Plug it up and I'm betting you'll get cool air out of the center cluster ducts.
Old Jun 6, 2006 | 04:31 PM
rudolph schenker
Thank you!
To Question on air conditioning?
