T-top question
Old Jun 12, 2006 | 05:46 PM
js292's Avatar
js292
Default T-top question
I know with c4's there are several different tops for different years, is this also the case with c3's? If so what are the differences and what years interchange
Old Jun 12, 2006 | 05:56 PM
rihwoods's Avatar
rihwoods
Think the big change is in the latch design / handles..my 69 has two latch handles,where my 78 has one latch handle.....and neither will fit the other..
Old Jun 12, 2006 | 07:12 PM
steveL82's Avatar
steveL82
Old Jun 12, 2006 | 08:19 PM
js292's Avatar
js292
In what year did they change? I need one for my 71 and this guy has a set from a 75
Old Jun 12, 2006 | 08:21 PM
C3nMe's Avatar
C3nMe
My '77 has two latch handles on each top ..so perhaps they changed with the '78 redesign.
Brian.
Old Jun 12, 2006 | 09:31 PM
js292's Avatar
js292
Thanks guys
Old Jun 12, 2006 | 11:40 PM
Z51JEFF's Avatar
Z51JEFF
I just bought a set of tops for my 81 and was told 78-82 were the same if thats any help.
Old Jun 13, 2006 | 08:30 AM
bluesilver82's Avatar
bluesilver82
should work. But you will probably need to shim them to fit your car. The top design for C3s changed in 78. I think late 78. Some of the early 78s may have the two handle design. You can buy the shims at any of the Corvette parts retailers. 68-77 same top....78-82 same top
Old Jun 13, 2006 | 08:59 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
68-77, same.
78-82, same.
Due to the hardware involved, the two types will not swap without changing out the hardware. Example: 78-82 tops on a 76. Works only when you change the 76 hardware to that of the 78-82 models.
Old Jun 13, 2006 | 10:00 AM
Nifty 71's Avatar
Nifty 71
68-77 are similar in design and should interchange easily
78 and up will fit the earlier years with an easy modification, remove the "triangle" head bolt from the rear side. I have glass tops on my 71, this is an easy mod.
To T-top question
