Just wondering if someone has experience replacing the rear-view mirror glass vs. replacing the entire mirror.
I have a 73 and was about to buy a new mirror when I saw a correct day/night replacement mirror insert available. I don't have the stock mirror handy right now to inspect for disassemble effort, but is this something that can be done without damaging the OEM mirror unit?
I have many, many, many replacement parts to buy. And it's getting to the point that saving $30 bucks on one thing makes a difference on buying something else. I'm sure many of you have been there done that.
I have not found new rearviews with the map light, if you have that option. Inserts are pricey though. If you dont have the map, buy a whole new one. Save seven years bad luck.
I have had sucess removing the old glass, and replacing it, it helps to keep the surrounding rubber warm and pliable, with a heat gun, and use a lubricant. Use a plastic (so it wont chip the glass) stick of some sort with a smooth end, and work your way around slowly. With patience, it can be done.
Be careful..... I bought a replacement from Ecklers for $50+ and it is a POS. Vibrates like mad at ALL times.
That's why I'm looking to possibly take the insert route. I've purchased serveral reproduction parts and many are not made to original OEM specs for fit and functionality.
Stingrai, so you're saying the mirror does not come apart, but it is plyable and you can just stretch the frame around the new glass if done carefully? I'll give that a try. Before I buy the replacement mirror glass, I'll try and take out the original mirror glass. If I break it taking the it out, I'll just take my chances with the complete repro mirror.
yeah...I just bought a mirror from Wilcox and it would not bolt down correctly to be held in position. It just falls straight down. So the I proceeded to try and tighten the screw farther thinking that this would work which of course only stipped the threads on the screw. Then after making a homemade very thin rubber shim to wedge in there and tighten down I ended up braking the aother bracket that attaches to the mirror so now I am ordering a whole bunch of new stuff. If this fails then I will find a good solid way to glue back on the old mirror.
Hogzilla, do you have pictures of your ride posted here? I have a 73 in orange and medium saddle interior. As I'm restoring it, I'm thinking of going yellow, but have been told to be very picky on paint choice and choice of painter. My understanding is that a sample of yellow paint can very drastically from the finished product. And most that want yellow want that deep rich color that I think you have on yours. Some even add tent to the clear cost to get that rich look.
What paint is on yours?
No, I don't have them on here yet, but there is a link below for you. I just bought the car and it's an original yellow 73', but it was repainted at some point so I have no way of knowing what paint code was used. Mine is a real nice shade, but in a year or so I will be repainting it and will be faced with the same problem.
I used a rearview mirror out of a mid 90s Pontiac Sunfire. It is a little smaller than the 82 original and has smoother design lines on it. It mounted right up to the existing fob on the windshield and only cost $5 bucks.
I was torn with the option for wheels; aftermarket or stock. I see your ride and kinda glad I went stock. I'll need to repaint a set of K-1-3 OEM rallies that I scored and have new derby caps and beauty rings ready to go.
Not looking for an NCRS restore, but it doesn't hurt to go OEM and actually save money.
Works great with our small windshields.
Brent...
Thanks Brent.
I'm going to try to remove the OEM glass. If that works, I can get what is stated to be the correct day/night mirror insert to put back in. But I can just see it now. A slightly different cut on teh replacement glass and everything fits but that last corner Ya gotta love working on these older cars. Keeps you reaching for more.
Thanks for the link.
The paint has a few issues.... chips, bubbling that will need to be corrected eventually. I am going with the same color, as long as I can find the right one. It's a good 20' car right now. It looks "good from far" and "far from good!"
Yes, it can be done. Did this on my 72 and turned out great. Smear a wee bit of clear RTV (silicone calk) in the middle of the base before install. Start by feeding the entire top or bottom portion of the glass into the frame and under the outer lip, then use a plastic/hard rubber scraper to lift the edge up and feed the glass in. Keeping the rubber frame plyable is the key...
Good luck
Eddie
