PS pump install
The PS mount bolts to the front of the block with two bolts. Remove it and install the pump to the bracket on the bench. Then, you just need it slide the stud on the back of the pump into the rear bracket and thread the two bolts through the main bracket into the block. Install the hoses and belt and tighten with the alternator removed. Lots of room to work that way.
