Yet another tire question
Old Nov 6, 2006 | 02:28 PM
Maco Shark's Avatar
Maco Shark
Default Yet another tire question
What size 15" tire will work on my 72 without rubbing or sticking out beyond the wheel lip?
I am thinking 255/6015 anything larger?
I am running stock rallye wheels.
Old Nov 6, 2006 | 03:13 PM
halfmoontrail's Avatar
halfmoontrail
I've got a killer stance, with 275/60/15 rears and 235/60/15 fronts, on stock ralleys.
Steve
Old Nov 6, 2006 | 04:40 PM
PRNDL's Avatar
PRNDL
Confucius say, man who run in front of car get tired!
Old Nov 6, 2006 | 05:10 PM
ETM's Avatar
ETM
Steve
Im due for a new set pretty soon..that sounds like what Id want..
Right now I have 255/60/15 all the way around..with minor rubbing in the front only in parking/tight turns..
Old Nov 7, 2006 | 07:38 AM
Maco Shark's Avatar
Maco Shark
Anybody else?
What size are you running on stock rims?
Old Nov 7, 2006 | 08:59 AM
Gary's 1977 Vette's Avatar
Gary's 1977 Vette
Default Tire size
Go to this site and put in what size you have now and then put in what size you want and it will tell you how much taller, widder etc. Then you can make your choice on what will clear.
http://www.1010tires.com/TireSizeCal...?action=submit
Old Nov 7, 2006 | 10:35 AM
Lon Wayne's Avatar
Lon Wayne
Default Tire pressure
Not to change the subject but does anyone Run the tire pressure shown on the drivers door? Mine Calls for 26 Lbs Maybe in 75 the tire was diff ??? Radial /Bias Ply
Old Nov 7, 2006 | 10:13 PM
greyghost79's Avatar
greyghost79
Confucius say, man who run in back of car get exhausted!
Old Nov 7, 2006 | 10:32 PM
greyghost79
too soft for my taste. 1 run 32 psi all around. dunlop GT's (rated for 38 psi max).
Old Nov 8, 2006 | 09:16 AM
1LE's Avatar
1LE
255-60-15 front and rear, no problem with rubbing.
Old Nov 8, 2006 | 10:42 AM
bwellisley's Avatar
bwellisley
Confucious say, man who drive with top down get blown!
haha, lame i know!
anyhow, what is the equivalent in today's tire to the original 15x7 and 15x8?
thanks
Old Nov 8, 2006 | 11:59 AM
halfmoontrail
haha, lame i know!
thanks
Those are rim sizes for '68, and '69-82, I think the original tires were F70-15, most comparable to a 215/70/R15
Steve
Old Nov 8, 2006 | 02:35 PM
bwellisley's Avatar
bwellisley
thanks
i have a 68, of which the car was at the end of the MY and has numerous parts for a 69. the wheels on it are 15x8, but appear to have some rub history in the wheel wells, figured i might get 15x7. these tires even look big...
do general tire shops have the ability to get a standard rally wheel in these sizes? or are these custom ordered? if so, where is good?
thanks for the info
Old Nov 8, 2006 | 07:52 PM
84rzv500r's Avatar
84rzv500r
Anybody else?
Stock? Nope!!!
15x11x4 with 325/50 15's
Old Nov 8, 2006 | 09:35 PM
greyghost79
Confucius say wife who put husband in dog house soon find him in cat house
Old Nov 9, 2006 | 01:44 AM
early shark's Avatar
early shark
I have a '71 with 255x60 on rear and 245x60 on front, no rubbing issues.
Old Nov 9, 2006 | 04:27 AM
Sprzout's Avatar
Sprzout
Stock Ralley wheels...
Are those the ones with those cone shaped hubcaps that go in the center?
I ask only because I didn't realize you could run a wider tire than 215's on them...I might have to reconsider them a little bit, then.
To Yet another tire question
Old Nov 9, 2006 | 07:46 AM
Maco Shark's Avatar
Maco Shark
They are stock rallyes. 15 X 8. 255/60 will go on 8 inch wheels easily, I was concerned about rubbing in the front on a 72.
I know later C3s like 79, you can run those with no problem at all.
Old Nov 9, 2006 | 09:01 AM
Jims79's Avatar
Jims79
Not true Shark, I had to put 245/60's on the front of my 79 w/255/60's on the rear. Looking at the car you can't tell right off the tires are different size.........A friend said to try 235/60 on the front but they looked too small. You can alway put the 225/70's on all four not a bad look & you don't have to lower the car to fill the wheel well.
Old Nov 9, 2006 | 11:39 AM
Maco Shark's Avatar
Maco Shark
If your 1979 came with factory aluminum wheels and had factory spoilers, you can run 255/60 with no problem. Again, if your suspension is stock. that was on my 79 back in the day. I bought one new.
The front fender lip on a 79 with factory spoilers has been removed from the factory.
If the car didnt have aluminum wheels and spoilers the front of the lip went down almost all the way.
check it out.
