Porter Cable makes about the best one and Autogeek.com runs deals on them all the time. Griots has a nice one also they sell in a kit. It's actually got a fan to cool the pad.
I am a huge fan of the Dewalt, and im in the business of detailing and painting cars. We have burned through a lot of polishers but the Dewalt keeps holding on strong. I have also heard Porter Cable was top notch but I havent had any experience with them.
The number one thing is to make sure you know what you are doing before picking up a high speed buffer/polisher. Its super easy to burn through the paint and go from Wowww to Ahhhhh Shiat!
This one from Harbor freight isn't bad for the money. I bought one and it did the job for me, just be careful and use the right grade compound for the job.It is now priced at $29.98 and is item number 92623 http://www.harborfreight.com/cpi/cta...unction=Search
I have the same one. It's a great buffer that gets the job done for less than $30
here's the important part: throw the foam pads that come with the buffer in the garbage can - they're junk. the wool pads (if they still include them) are ok but don't last long....
Buy a 3M dark foam pad - that's really good stuff but almost as expensive as the buffer
HarborFreight also sells the velcro backing pad separate, they're only $5 on sale
By his post, all I think he needs is a polisher. A buffer is overkill for small swirls or scratches.
The beauty of the Harbor Freight model is it is both a buffer and polisher. It has a range of 200-3300 RPM. For the paltry price of under $30 bucks you get both and it comes with a backing disk and enough pads to get you started polishing or buffing. This is just my opinion and I have no interest in HF.
I just bought a polisher kit for the drill, it's a small backing plate that screws into a 3/8" mandrell.... comes with four pads, (2 foam and 2 wool pads), $20 and gets all smaller jobs done.
Very cool. I'm going to give this a try as well. Paint isn't bad, but its got some swirls. I know that 3M has a swirl removing compoud as well.
foam doesn't cut very well. this is like what I use... http://cgi.ebay.com/JESTCO-Aluminum-...QQcmdZViewItem I don't have that exact kit, but that's the supplier I use. It works great for aluminum rims and for small areas. I believe that you're looking for something like this instead of a buffer. I use these on my die grinder and they work amazing. I used to polish my aluminum rims by hand, and this cut the time dramatically and I get much better results.
Had a different buffer and sold it for a porter cable
a) a polisher, by this I tend to think of the porter cable unit, for applying wax or polish onto the car. Easy application, reduces swirl marks etc etc.
b) a buffer, commonly a variable speed unit used for the finishing of paint. With wool or foam pads, used with variable grades of buffing compound, from heavy to remove scratches to a final glaze. I have the makita, excellent results with it.
Yea I just need to work out some small things that I suspect my car cover did...
Did'nt realize car covers scratch the paint.... thought they were to protect the paint! POS......
Again, thanks I think I'll go with the porter cable.
I used to buff cars in highschool for a local dealership so I'm not afraid of burning the paint. Just need to get the feel for it again! Its been 15 years.... Damn I'm getting old....
same one i bought from harbor freight ,,got a free stainless thermos and a stainless travel coffee mug,,,not bad for 29 bucks,,from our good friends in china...chicago electric,,,,,chicago,,china.....just like the old days when knock off stuff came from usa japan----usa instead of u.s.a----pronounced yousaa
Also, if you're using a lambs wool pad, be careful of things like wiper arms and aerials - you'd be surprised how easily and quickly a buffer can remove them from the car for you!
This site has all you need to know about buffing. I converted an old 3/4 HP electric bench grinder into a buffing machine. Their kit for about $110 covers just about any metal you need to polish. http://www.caswellplating.com/buffs/buffman.htm
