door henge
Old Feb 23, 2007 | 05:05 PM
1yy07's Avatar
1yy07
Default door henge
can i swap out one at a time? and do i have to take off spring on the top one?
Old Feb 23, 2007 | 05:10 PM
brdd's Avatar
brdd
From: Minnesota in the summer, Las Vegas in the winter
Sure you can. You can do it any way you want.
Last year I took the doors off completely. I spent a lot of time cleaning up the "armpits" of the door. I cleaned and painted the hinges. Then new springs. They were worth the effort. If you're not afraid to remove the doors this is a good way to do it and a good project to do. But you don't need to take off the doors to change springs. The special bent screwdriver-type tool would help.
Old Feb 23, 2007 | 05:19 PM
1yy07's Avatar
1yy07
does the spring have to come off to swap out the top one?
Old Feb 23, 2007 | 05:45 PM
brdd's Avatar
brdd
If you are asking if the spring must be removed before the top hinge is removed, the answer is no. You can remove the hinges with springs intact.
I hope I am helping, not confusing you.
Dan
Old Feb 23, 2007 | 06:46 PM
Chuck Gongloff's Avatar
Chuck Gongloff
Active Streak: 90 Days
The upper passenger's side hinge is easy to get out.
The upper driver's side hinge is a PIA.
You literally have to remove the dash cluster to get to the bolts.
The spring is part of the hinge assembly, and does not have to be removed to get the entire spring out.
Chuck
Old Feb 23, 2007 | 09:45 PM
Love My 72 and 77's Avatar
Love My 72 and 77
stonehenge
Old Feb 23, 2007 | 10:46 PM
bwellisley's Avatar
bwellisley
Chuck
AAAAARRRGH! I just had all that out for the re-wiring, and I need to replace the Driver Upper hinge!!!!!
Old Feb 24, 2007 | 03:17 PM
1yy07's Avatar
1yy07
thanks for the help!
Old Feb 26, 2007 | 10:31 AM
UKPaul's Avatar
UKPaul
Originally Posted by Love My 72 and 77
stonehenge
No, THIS is Stonehenge
http://www.youtube.com/watch?v=dU3H1Um4Ju4
Obvious really, but make sure that you support the doors when working on the hinges.
Old Feb 26, 2007 | 07:55 PM
gmg1977's Avatar
gmg1977
My passenger side spring was easy on mine when I changed out doors. It just broke in half by rust.
To door henge
