78-82 Stereo install question
Old May 7, 2007 | 10:16 PM
swtato's Avatar
swtato
St. Jude Donor '05
Default 78-82 Stereo install question
For those with a 78-82. I bought an extra glovebox shell to possibly modify to put a head unit in there? Has anyone tried this or think it would work? I have never spent any time inside or behind the dash?
Old May 7, 2007 | 10:31 PM
spedaleden's Avatar
spedaleden
In the glove box will work. Mounting the radio in the rear of the glove box won't. I think Metra makes a mounting plate that is L shaped, so the mounting plate mounts to the lower part of the glove box and the radio mounts to the plate.
The only problem is the glove box needs to be open to make adjustments.
Old May 8, 2007 | 09:25 AM
swtato's Avatar
swtato
St. Jude Donor '05
So there is enough room to mount in the glovebox? I asume the back of the plastic glove box liner would have to be cut? Where might I find one of these mounting plates? I usually only listen to one station so no need to really switch alot plus I think I will add a Ipod so that should be fine. Thanks for the help.
Old May 8, 2007 | 06:41 PM
smthnpls's Avatar
smthnpls
As not to alter the orig look of my dash (keeping the orig FM/cassette radio), I mounted a newer stereo/CD player in the glove box. I also bought a new box for when I would sell the car in case the new owner had a problem with it. I placed it on the bottom of the glove box and put small stick-on plastic hooks (with the ends slightly cut off) to hold it firmly against the back of the box. I had to cut out a small hole to allow the wires to feed through. It works fine. It's just a pain in the a$$ somtimes having to reach over all the time to change the station or the CD.
Old May 9, 2007 | 08:14 AM
swtato's Avatar
swtato
St. Jude Donor '05
[QUOTE=smthnpls;1560169253]As not to alter the orig look of my dash (keeping the orig FM/cassette radio), I mounted a newer stereo/CD player in the glove box. QUOTE]
That is exactly what I want to accomplish!
Old May 9, 2007 | 11:13 AM
worship79's Avatar
worship79
My Pioneer headunit didn't fit in the glove box (without cutting out the back of the box or mounting it sideways, which would be useless ofcourse), so I just went ahead and bought a new center cluster bezel. Figured if I was going to mess with the dash anyway, might as well make it practical and safe. And this way I can always go back to original. Bezel costs about 55 dollars new.
Old May 9, 2007 | 02:58 PM
swtato's Avatar
swtato
St. Jude Donor '05
I bought an extra glove box liner so cutting it is not a problem. I just don't want to give someone an extra reason to break in the car!
Old May 9, 2007 | 10:43 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Why not get a repop center cluster with the DIN hole and put your original plastic and stereo away? Best of both worlds, you can always re-install the stock stuff later. Conversion harnesses that let you plug your new head unit directly into the stock wiring are readily available.
Old May 9, 2007 | 10:49 PM
swtato's Avatar
swtato
St. Jude Donor '05
I think he has the same idea I have.
1. keep original look.
2. a theft deterrent.
3. best of both worlds original look, modern technology.
Old May 10, 2007 | 01:36 PM
Ak. Mal's Avatar
Ak. Mal
From: Kansas City, MO ...I'd like to go fishing and catch a fishstick. That'd be convenient. - Mitch Hedberg
For those of you adventurous enough, I have a solution for you. Mount the cd player in the glovebox and the removable faceplate in the shift plate under the ashtray door. Connect all the contacts using a ribbon cable. Now you have a radio/cd player that you can operate safely, hide under the ashtray door and keep the stock radio in place. To make it even better, add a changer to the storage compartment or get a cd player that will play mp3's. I have several discs with only mp3's on them and they will hold 10-15 full length albums in that format.
To 78-82 Stereo install question
