Roadster Question
Old Jul 31, 2007 | 09:12 AM
2005bobby69's Avatar
2005bobby69
Default Roadster Question
Has anyone made a roadster from a t top car ?
If so is there any pictures and what did it take as far as bracing?
If done where could i find info conv or roadster does not bring anything up in the search
Thank You
This is going to possibly be a roadster with no conv top everything shaved and removable hardtop
Old Jul 31, 2007 | 09:58 AM
71rdster's Avatar
71rdster
I helped a friend do it on an 81. I did all the fiberglass work and paint. He had done an 80 previously. No special bracing, though I am pretty sure that the doors will sag a bit after a while. That can be fixed with retrofitting the door support pieces. Parts are readily available. Others on the forum have done it or are in the process.
Old Jul 31, 2007 | 10:29 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Purchase the AIM for any year where convertibles were available. Compare the coupe and convertible installations, including the bird cages. That will give you an idea of what is involved going from coupe to convertible. Convertible deck lid with hardware, the rear surround panel, and folding tops irons will be your biggest expenses. Door glasses could get pricey.
If you're careful dismantling the coupe, you might be able to sell the parts from the coupe to recover some of your costs.
To Roadster Question
