speedo/tach not lighting
Old Oct 7, 2007 | 08:16 PM
mod81's Avatar
mod81
Default speedo/tach not lighting
so everything on my dash lights up, but no speedometer and tachometer lights? I dont get it, its all hooked up, I checked fuses. any clues?
Old Oct 7, 2007 | 11:28 PM
mod81's Avatar
mod81
bump...somebody?
Old Oct 8, 2007 | 07:22 AM
Durango_Boy's Avatar
Durango_Boy
The light sockets for those gauges all ground through the gauge housings. I would guess the gauge housings are not grounding.
Edit: Late C3 gauge clusters may have a different light / ground system.
Old Oct 8, 2007 | 12:42 PM
Lon Wayne's Avatar
Lon Wayne
Default Vader Vette
Mine has kinda the same problem It seems i have one or so lights but then when I push on the top of the chrome bezel somemore start to light up but when I releive the pressure they go back out .It does seem like a ground but what is pushing doing .does anybody know what the bulb socket looks like maybe its just rusty???
Did you pull down your dash board? The bottom of the wheel comes loose and the dash has more room to move down after that.
Old Oct 8, 2007 | 01:04 PM
Young69Owner's Avatar
Young69Owner
What color is the wire that goes to the gauges? Mine is gray. Mine just fell out one day when I was living in Colorado. I didn't fix it until 6 months later. I would find it.
Old Oct 8, 2007 | 03:17 PM
Artsvette73's Avatar
Artsvette73
Well you guys have the printed circiut on the back of the cluster. You would be looking for a black wire that will be your ground. The gray wire is the feed for the lights from the headlamp switch. It maybe the circuit board that is not making contact or it is burnt. Or no feed from the switch. Pressing on the guage and they come on I would guess it is the connector to the circuit board behind the panel to the gauge cluster,
Old Oct 9, 2007 | 07:39 PM
mod81's Avatar
mod81
ok...so now the little "brights" symbol in the middle will light up, but still nothing on the guages...the harness seems in good shape, and the connectors on the circuit seem good and clean. I'm so lost. Fuses are good...I checked.
Old Oct 9, 2007 | 08:02 PM
mod81's Avatar
mod81
problem solved...i have a small tear in the circuit that I failed to notice before...I guess I need a new circuit
Old Oct 10, 2007 | 08:47 AM
jdp6000's Avatar
jdp6000
No you don't fix it. Two choices buy a soldier gun and copper soldier or take it to a radio TV repair guy and have him do it.
Jim
Old Oct 10, 2007 | 10:57 AM
spedaleden's Avatar
spedaleden
You can put a jumper wire over the break. Just soldier at each end of the wire to the circuit tape/board.
To speedo/tach not lighting
