Vacuum Hose Sizing
Medium Black
Small Black
Small Yellow
Small Blue
Small White
Large Yellow
Large Green
Large Red
Large Black
Hoses:
1.) Medium Black 4" - Intake manifold fitting to Plastic filter
2.) Medium Black 20" - Plastic filter to metal valve (near manifold connection)
3.) Small Black 30" - Metal Valve to "T" connector under dash
4.) Small Yellow 11" - "T" connector to wiper door solenoid
5.) Small Black 18" - "T" connector to headlight switch
6.) Small Blue 18" - Headlight switch to headlight manual override valve
7.) Small Blue 16" - Wiper solenoid to manual override valve (Wiper door)
8.) Small White 52" - Wiper manual override valve to wiper arm safety valve (under wiper)
9.) Small White 100"- Manual headlight valve to "T" between headlight relay valve caps.
10.) Large Yellow 13"- "T" connection near reservoir to middle port on wiper door relay valve.
11.) Small Black 15"- Wiper safety valve upper port. (Vent line).
12.) Small White 36" - Wiper door relay valve cap to bottom port on wiper safety switch.
13.) Large Green 28" - Bottom port on wiper relay valve to wiper door actuator rear.
14.) Large Red 31" - Upper port on wiper door relay valve to front of wiper door actuator.
15.) Medium Black 17" - Plastic filter to vacuum tank. (Reservoir supply)
16.) Large Yellow 77" - Reservoir to left headlight relay valve center port. (Supply)
17.) Large Yellow 84" - "T" near reservoir to right headlight relay valve center port (Supply)
18.) Small White 14" - "T" connector between headlights to RHT headlight relay valve cap.
19.) Small White. 14" - "T" connector between headlights to LFT headlight relay valve cap.
20.) Large Red 23" - Top port of RHT relay valve to rear of RHT headlight actuator.
21.) Large Red 23" - Top port of LFT relay valve to rear of LFT headlight actuator
22.) Large Green 16" - Bottom port on RHT relay valve to FWD port on RHT light actuator.
23.) Large Green 16" - Bottom port on LFT relay valve to FWD port on LFT light actuator.
24.) Large Black 9" - Vacuum reservoir to "T" near reservoir. (About 9" away near fender)
thanks
I will check this afternoon and let you know
http://forums.corvetteforum.com/show....php?t=1867043
Medium Black
Small Black
Small Yellow
Small Blue
Small White
Large Yellow
Large Green
Large Red
Large Black
Hoses:
I'm after the exact diameter of the green hose from actuator to relay valve. All I find is the length size.
Simon
Thanks for your reply but I'm still after the diameter of the green hose and now the red hose. When I search for the sizing I'm unable to find the answer anywhere.
Simon
