1969 numbers or just parts
I have a 69 that I think is just a bunch of parts put in it. The vin number is 194379s712479, which is I think is early december 68 or Jan 69. On back of block drivers side is GM 3970014, on pass side is T2, it has a holley 4150double pumper 800 cf with a winters 3972116 GM aluminum intake ,solid lifter cam, the heads are GM 35 3927186-L98 the heads have push rod guides is this the correct numbers for a 350-350hp ,I know the intake is not correct, or solid cam, the engine was rebuilt on the Lt-1 370hp specs, has 11 to 1 compression,lumpie idle, runs like a Bear with octane booster, is this correct block or what? The car has a original L-88 hood on it. Any help would be appreciated on what I got.
Location: About 1100 miles from where I call home. Blue lives matter.
Received 5,325 Likes
You have an original L88 hood? Do you have pictures of this?
194379S712479 = January 10, 1969 birthday (you can confirm by checking the number on the driver door trim tag - should read F9 or F10).
3970014 is a 1972 2or4 bolt block - it is not original to your '69 .. not much is known about it - there will be some numbers on the front passenger side pad - what are they??
3927186 is the original head numbers for the 1969 corvette - L98 date reads December 9, 1968 ... which is in line with your car build date.
3972116 is a service aluminum intake for the 1970 LT1 350/370 engine.
On the front of the engine on the passenger side about where the head and the water pump come close, there is a stamp pad that should look similar to this one.
If you can get pictures of it or tell us what is there, we can help you know what the engine is. However, the -0014 block was typically in early '70s Chevrolets. It is possible to be found in late '72 and early '73 Corvettes, but I believe it is not very common in those.
If you take a picture, you will need to use the macro function in your camera. You may have to shut off the flash, as sometimes they wash out the picture and you can't see anything. Be sure to check the picture and take another if in doubt. Then upload it to a website and post the IMG link here.
The numbers are cut off only if the deck was cut. That doesn't happen in a standard rebuild, but in a performance rebuild or if the block had been overheated and warped the deck. This is why a large clear picture will help, as most can tell by the cut marks if the block is decked, original, or what.
But if any factory broaching is seen, the numbers should just jump right out. So maybe this is an OTC short block or bare block.
Decked blocks tend to be really sharp on the edge, and this one doesn't look that sharp. Also, the circular cutter marks are usually seen, unless someone uses a belt sander to hide them and try to create "broach marks" which doesn't appear to be the case here.
So really, if it runs, then it is great. Any original configuration or installation is a non-issue since you can't identify it as a Corvette or Camaro engine which might be worth a few dollars. So just enjoy it and drive it. It isn't the original and it isn't an NCRS correct one, so you get the pleasure of having NOM freedom.
Drive and enjoy.
Tough to be too sure in pictures, but the design looks pretty good, especially the underside configuration.
Can someone tell you if it if press molded as opposed to hand laid?
Vettebuyer--I got this car from my brother last year and he worked at a corvette place in St Louis Mo and he said it was a original L-88 hood, are these hoods something special, I know corvette only made few L-88 engines in 67,68,69 but I didnt think the hoods were a big deal, you see the them on alot of cars, maybe repoductions?---THANKS JON
The hoods are and aren't special in themselves. They are because they are part of an L88. They aren't because like the engines themselves, they were readily available over the counter for years. But at Chevrolet prices as opposed to Eckler prices and others.
So many you found back then were aftermarket for price alone. Many you find today are aftermarket because of availability.
And price is a heavy factor now, too, as people with real L88 cars need those hoods for correct restorations and people building clones need them, too, for accurate clones. After all, you wouldn't want a buyer to detect it is only a clone, now would you?
But after yesterday, they all became completely worthless due to a new law passed, so if you want, I can tell you how to ship it to me and I will dispose of it in a "green" manner.
