ARP head bolt torque question
Old Mar 17, 2008 | 06:13 PM
Surfer69's Avatar
Surfer69
Default ARP head bolt torque question
I'm getting conflicting info from ARP. Their sheet that comes with the bolts says 65 ft-lbs using their lube. An email to them comes back saying 75 ft-lb using their lube. I know you lube or seal the threads but what about the head underside and washer underside.
Is the torque accounting for dry head and washer or lubed?
These are 12 pt 170/180 ksi head bolts. Aluminum heads.
It may not be a big issue but if you use 30wt oil, 65 becomes 85 by their spec. I just want to know if anyone is factoring in the head and washer lube or not which can make a difference in true bolt preload.THX
Old Mar 18, 2008 | 08:39 AM
jimvette999's Avatar
jimvette999
Use the lube on all friction surfaces and burnish fasteners by cycling them 4 or 5 times prior to sealing threads and torquing to final spec. You only need to loosen a half a turn the re-torque. I would use the 75ft/lbs on bolts.
Ask your question over here>>> http://forums.corvetteforum.com/forumdisplay.php?f=7
You'll get more responses from engine experts which I don't happen to be.
Jim
Old Mar 18, 2008 | 07:57 PM
C3 Stroker's Avatar
C3 Stroker
Jim
I use this same method, and always a final torque of 75ft/lbs.
(I tried 65ft/lbs. at first, but later had to retorque when the bolts loosened up.)
Old Mar 18, 2008 | 09:39 PM
noonie's Avatar
noonie
Their lube is Moly and it is sustantially slicker than 30wt motor oil. The srface area between the washer and bolt head should be lubed. I always go a couple pounds over the spec. ARP can handle it and good head gaskets won't care.
Old Mar 19, 2008 | 12:35 PM
Surfer69's Avatar
Surfer69
That's interesting C3 about your bolts loosening up with 10 ft-lb undertorque. Three bolts on my AFR's just loosened up when I used
30WT and went to 75. ARP now says it should have been 85 with 30Wt so I may have undertorqued. I did cycle the bolts 3 times during initial build.
They also say for Aluminum heads to only go 60 instead of 65 with their Moly. AFR recommends 65-70. I think I'll end up going 70 with the Moly lube under the heads and their thread moly sealant.
Old Mar 19, 2008 | 12:49 PM
stinger12's Avatar
stinger12
I beleive Gary Ramadei had this issue with ARP as well regarding the ring gear bolt torque. He couldn't get a straight anwser from them, as everyone kept telling him conflicting different torque numbers. I guess it all depends on the person you talk to on the phone...
Old Mar 19, 2008 | 03:19 PM
7T1vette's Avatar
7T1vette
I would advise that you do not exceed specified torque levels when installing steel bolts in aluminum heads. The dissimilar metals "grab" better than like metals, so they don't require as much torque; also, the aluminum threads are not as strong. You might be better served to keep oil out of the threads and install them with some thread locker to keep the bolts from backing out.
Old Mar 20, 2008 | 07:49 PM
C3 Stroker's Avatar
C3 Stroker
Just curious...does anyone use locktite (of any kind) on head bolts?...I've never heard that done..
Old Mar 20, 2008 | 10:32 PM
noonie's Avatar
noonie
Since the head bolts go into the water jackets then no oil should be used and only a non hardening thread sealer such as ARP also has available. The oil should only be used between the bolt head and the hardened washer. Most cheaper aftermarket chevy bolts come with the sealant already on the threads.
The only problem you might have with moderate over torquing with arp fasteners is possibly crushing the head gasket. The good MLS gaskets for aluminum heads are designed to move a bit within themselves, but not against the block or the head surface and the vast majority is caused by the different expansion rates of each meaterial.
As in most cases, the better the product the better the result.
Old Mar 21, 2008 | 05:04 PM
C3 Stroker's Avatar
C3 Stroker
Thread sealer in water jackets, definitely. But 7t1vette suggested thread locker which is not really recommended for head bolts.
To ARP head bolt torque question
