Engine Additives
Old Apr 15, 2008 | 10:27 AM
GORDO79's Avatar
GORDO79
Default Engine Additives
Has anyone used the Corvette Engine Oil Additive, ZDD Plus™ from Ecklers? Never been a fan of additives but always looking for new products and if they work.
Old Apr 15, 2008 | 10:51 AM
Durango_Boy's Avatar
Durango_Boy
Is there something specifically you're trying to fix with these additives?
Old Apr 15, 2008 | 01:23 PM
GORDO79's Avatar
GORDO79
No Not really - Just curious if anyone has used it.
Old Apr 15, 2008 | 01:25 PM
400hp427vette's Avatar
400hp427vette
St. Jude Donor '09
I use Zmax every other oil change
Old Apr 15, 2008 | 01:28 PM
Mark_Milner's Avatar
Mark_Milner
Is ZZD one of the Teflon additives? If so, STAY AWAY from it. The Teflon tends to clog the filter and the pump intake screen.
Old Apr 15, 2008 | 02:30 PM
Bowerss2's Avatar
Bowerss2
i think its a zinc additive, put back some of the wear metals that are not found in modern oils, i just use shell Rotella T
Old Apr 16, 2008 | 05:02 PM
jpatrick636's Avatar
jpatrick636
I'm a big fan of Z Max.
Old Apr 16, 2008 | 05:10 PM
rihwoods's Avatar
rihwoods
Here it is...
http://www.ecklers.com/product.asp?p...98&dept_id=121
Old Apr 16, 2008 | 05:12 PM
Jon Hekking's Avatar
Jon Hekking
I spent 28 years in the Automotive Aftermartket with the country's largest distributor of auto parts and supplies and there is not an additive I would waste my money on. They are pure profit and do very little if anything to enhance engine performance or life. The companies that make these love to create the hype..............
Old Apr 16, 2008 | 05:25 PM
rihwoods's Avatar
rihwoods
Nothing wrong with a Zinc additive for flat tappet cams...one could argue once cam is "broke" in, you could go to Syn...but wear is wear,and I would not risk it..
Old Apr 16, 2008 | 09:33 PM
Mike Ward's Avatar
Mike Ward
Naw. really?
Old Apr 17, 2008 | 07:02 PM
skipinhouston's Avatar
skipinhouston
IMHO.........
Shell Rotella T is the oil of choice since manufacturers have taken a lot of the additives out of our regular oil choices.
We've experienced cam failure on two new rebuilds and on a newly broken in motor after changing the oil after the breakin (with Penzoil 30 wt.).
Comp Cams recommended running 1/2 bottle of breakin additive per oil change on regular (non-synthetic, non-Rotella T) oil to compensate.
On our cars, do not use synthetic unless you're willing to accept the possible consiquences.
Like the man says, you pays your money and you takes your chances.
Skip in Houston
To Engine Additives
