Thanks for all the comments. I can see the rear needs a new spring, with 3/4 tank of fuel and nobody in the car, the spring is flat. That will be a project for next winter after the budget recovers a little. I could put in shorter bolts to raise it up a little in the rear, but that spring is shot.
That made all of the difference. I personally like it just as it sits now. The wheel well gaps look nearly even. If it were mine I would leave it as is.
