turn signals
turn signals
81 vette
when i turn on a turn signal nothing shows on the dash. and my right turn signal is a little dim when on. i replaced the bulbs and still nothing.
is it the flasher or something else.
Thanks for the help
Thanks for the help
Had the same problem and i fixed it last night. One side was not working and i swich bulb to see if it was the bulb and no change, both bulb were ok. My problem was the socket itself that the bulb goes into and screw on the dash. I just bend the litle tab to make it tighter and it work. Make sure your electrical layout on the dash is not bend or misplaced so when so screw the connector it does have a good contack with it.
well i checked all the bulbs and there all tight. my left blinker works fine but the right one just just stays lit. when i turn them on nothing appers on the dash but i can here them bliking.
St. Jude Donor '08
I would go ahead and replace the flashers. Are the turn signal lights (front and rear) blinking? If they're not it sounds like a flasher problem to me.
