Synthetic oil after break in
From reading this i think i found my problem of my old engine. I did swich from semi-synthec to full syntech last year and by the end of the year i had one piston that was'nt working,probably the cam had gone bad.
Royal Purple Break-in Oil
Engine builders using flat-tappet cams have grown increasingly concerned that many modern motor oils do not provide adequate wear protection for new engines, particularly those using flat-tappet cams. Royal Purple has addressed this issue by developing a new engine break-in oil.
Royal Purple Break-in Oil is formulated to allow optimal ring seal and protect rotating assembly components such as the camshaft and valve train from initial start up wear. Royal Purple combines highly refined mineral oil, preferred for engine break-in, with advanced additives containing high levels of zinc and phosphorus to optimize protection in flat-tappet and roller engines.
Royal Purple Break-in Oil is fully formulated and does not require the use of any other chemical additives. Royal Purple recommends using their high performance motor oils after the engine is broken in for maximum engine performance.
http://www.royalpurple.com/breakin-oil.html
Cost about 7 bucks a quart this way.
Last month's Corvette Fever did a long article on how flat tappet cam engines need zinc in the oil. They noted that synthetics may be too slick, that the lifters might not even rotate in their bores which they are supposed to do. That issue is probably still on newstands, I just got the latest issue last week as a subscriber. I thought the article was a good read and very informative.
I gotta remember to take Corvette Fever OFF my "must read" list.
If your new engine has a hydraulic cam and lifters, and not a modern roller cam ( post 86 vette) then you should contact your cam manufacturer for advice on oil, and I suspect they will tell you that most current oils have decreased zinc and phosphorus formulas due to EPA requirements to extend the life of catalytic converters, and because roller cams in modern cars don't require that formula. Your cam manufacturer may recommend a particular oil- like Valvoline Racing oil which allegedly still has the additives: or Shell Rotellla Diesel, which also has the additives, but now in reduced amounts. Your cam manufacturer may also recommend an additive to regular 10W30 dino at every oil change. I suspect that synthetic oil wil not be recommended for atleast 5K miles after break-in, or not at all if someone had old or original factory gaskets, due to the potential for leaks. Corvette Fever magazine just did an article about the purported bad effects of synthetic oil on the movement of lifters in the bore- thus causing an undesirable wear pattern. but i have not heard this previuously. So contact the manufacturer of your new cam and get some further advice. I just rebuilt my engine to a 355 with a mild Lunati VooDoo cam and lifters, and have decided to use 5W or 10W30 Dino oil with a half bottle of GM EOS added at every 3Kmile change. Good luck with your research and decision. Jim
