Still Won't Start !
The no-start problem also sounds like an electrical problem. If the car used to start before you installed the remote system them your problem might lye in the wiring of that remote start kit. Try removing it and putting it all back to the way it was when it ran and see what happens.
Do you have a wiring diagram of your car's ignition system so you can make sure you have all the proper wiring and delete the un-needed Bubba wiring that cam on the car?
The switch went out, so I thought, in start mode the guages would dim, but nothing happened, not even a click. That's when I put the remote one on. I did disconnect the remote switch. Even with the new switch it did the same as the old switch. I also put a different coil, no change.
Have you checked the fusible links at the starter?
It's the other way around. The power comes from the starter to the coil.
Fusible links, when they block, get burned from the cylinder to the end of the end of the wire. It's that short length that's the link that cab blow or become weak.
you got way to many variables going on.
start with your basics.
1. you need 12V solid at the starter, with good connections,
if you have this you should be able to jumper the start solinoid and the starter should crank all the time.
2. you must have 12v for your ignition,
if you have this you will have spark at any plug wire during cranking.
3. figure out the mechanical problem with the starter,
sounds like your ring gear is chewed up, make sure your starter is setup proper clearance with the ring gear.
4. forget the remote start unil you have ever thing working correctly.
An easy way to check what I was talking about, is run a jumper wire that you are sure has 12 Volts to the coil +. If the car does start you will need to kill power to this wire to get the car to shut off. Just be sure you can break the power going to this wire while the engine is running. You can run it to switched power or however you like for the test. That should eliminate any problems with the wiring coming from your starter.
I put the remote on after the factory switch went out, the solenoid went out first. I can jump the solenoid with a screwdriver.
