carpet bubbles NEED HELP
Old Aug 10, 2008 | 10:28 AM
itslaf's Avatar
itslaf
Default carpet bubbles NEED HELP
how do u get rid of the bubbles in the carpet? its not glued down yet but it almost seems like theres to much for it idk. here are some pics.
Old Aug 10, 2008 | 10:34 AM
Duke94's Avatar
Duke94
Use a heat gun or hair dryer. You may also need to use a little carpet adhesive, but most times the heat will do it.
Old Aug 10, 2008 | 10:55 AM
itslaf's Avatar
itslaf
yea i do have the spray adhesive. should spray it down so it sticks and then use a hair dryer? or use the hair dryer first then use spray adhesive to make it stick
Old Aug 10, 2008 | 11:36 AM
Duke94's Avatar
Duke94
Use the hair dryer first, then glue if you still need it. Use the hair dryer on the back side where you can still lift it up.
Old Aug 10, 2008 | 11:45 AM
Alan 71's Avatar
Alan 71
On some places I needed to VERY carefully trim the perimeter of the carpet so it could lay flat in the center of the piece I was working on. Your second picture looks like there needs to be some trimming of the carpet to get it to fit smoothly around the console bracket.
Regards,
Alan
To carpet bubbles NEED HELP
