Different idea on paint color
#42
The code # probably varies with the year of the Ferrarri paint, just like with other car makes. The shading by year group may also vary slightly due to a slightly different blend.
I know that my numbers are correct for the colors as I went down to PPG paint in Orange County, CA and looked through their catalogs and ordered the paint directly.
Also, I have the two cans (this and Canna Di Fucile) and am looking at the actual number on the can. PPG is blue letters as a "watermark" so I think I know of which I speak.
OEM 704C Ferrari
BC37032 A, GRIGIO TITANIO MET
I can also provide the mix contents off the can if you want to compare those.
I had it done 2 years ago. Based on the pics, yours looks like a whole different color. But then, pics do that.
OEM 704C Ferrari
So why the variance in what you have and what I have and what the Auto Color Library has I do not know.
BTW the 2nd body shop repainted the tail Cap AFTER I had the car initially painted and you can not tell any difference in the color - I gave him the PPG code of 36801 and if you go to the AutoColorLibrary site you will see the name matches to what you have as well so go figure.
#43
Yes, I followed the link. Like I said originally, mine is from a late model Ferrarri while yours is obviously from an earlier model.
Quote the % of each admixture off your can and I'll tell you if they are the same color.
#44
Sorry, no I don't need to "Learn any more", if I wanted to be a painter I would have taken that up a long long time ago. I took a different career path, but thanks for the suggestion. What I will do is pass both codes along to my body shop and ask them. Since "That" is the career path the shop owner took, I am sure, that he being the expert will know an answer to this curious problem.
#46
1 Post
CF Pit Crew
Cruise-In I Veteran
Cruise-In II Veteran
Almost CI III Veteran
Cruise-In IV Veteran
"Thou shall not covet..."
Every time I see a picture of your car, I get really jealous.
Beautiful car
[QUOTE=78Vette-SA;1566918976]Just for a possible other option in your decision making process - C6 Lemans Blue.
Beautiful car
#49
3 or 4 of us with elkhearts have all posted in the same thread before, and none of ours look the exact same. the pics i put up earlier are also elkheart, and they look worlds apart from the other one that was just posted here. both done in lacquer.
#50
Yes - it's stock.
Depending on the sun, camera, and believe it or not polish and wax used, etc. the color does tend to look a bit different.
Here's a couple more - same car different wheels:
#51
I agree - light and background really change the look of this color. My paint is also 22 years old I am sure they all look a bit different after a while
#52
That's the color! Cadillac White Diamond....beautiful!
