Exploding car battery, that was a close one...
On the morning next day I disconnected the battery from charger and tried to lift it and put into the car. Just as I touched it, it exploded, covering the oposite side of the wall with acid & plastic pieces of the battery! I was sooo lucky, that the whole blast of explosion went to the opposite side, not where I was standing.
What a f*&^% was that? Ok, I knew in theory that batteries explode if overcharged, but was totally not expecting this to happen with completely new battery!!!
Ken
When I looked at the battery afterwards, the lever of fluid in the battery (remaining after explosion) was rather high and it was still in the battery. The explosion just teared the upper part of the battery.
Now I'm thinking, what is causing such a quick drain in my car. As I wrote earlier, it is '68 and it has non-working wiper system. I am suspecting it to be causing the drain.
Anyhow, I'm confused now as I don't know the reason. I do not want to get some kind of exploding batteryphobia now
Ken
The outgassing could damage the battery if overcharged or charged at too fast a rate. Better to use a lower charge rate for a longer time.
Anyhow, looking at the future, now I will allways disconnet my battery after driving the car, before I find the source of drain.
Damn, now I have a new phobia: battery-charge-phobia
On 68 if the **** under the steering wheel between the two vacuum switch valves is in on position you get power to the wiper motor directly all the time not through the ignition switch and it will drain your battery and some time will burn your wiper motor.
Avner
* When charging a battery, top the cells off with distilled water.
* "Maintenance Free" batteries aren't really that. Unless you are using a gel type of battery, there should be a way to remove the cover(s) to allow the battery to breath while charging. Don't rely on the vented cover or caps to vent the battery while charging. The battery will build up hydrogen gas and any small spark can cause the battery to go ka-boom!
* As stated earlier, the best type of battery charger is one with an auto shut off when the charging has been completed. Also, when the battery has been charged. Unplug the charger from the outlet first, then disconnect the charging clips from the battery. This prevents any sparks from occurring near the battery. See notes about Ka boom!
* Always wear eye protection when working on batteries. Battery acid in the eyes will make for a bad day. You should also wear rubber gloves when handling batteries too. Battery acid doesn't play well with skin. If you spill battery acid on you clothes, most likely it will eat it away where it touched the clothing. The only type clothing that seems to hold up surprisingly well is 100% polyester base clothing.
*When re-connecting the battery cables onto the battery after it has been charged, I install the positive (Red) cable first, then the negative (Black). Remember, wear safety glasses when doing this. See the part about sparks and Ka-Boom!
I hope this information helps.
Good luck!
