First Vette
It is a 76 Stingray. It is in "fair" condition. The engine is a rebuilt 350 that runs strong. The auto transmission shifts as it should. It has an aftermarket paint job of Silver with a black stripe on the hood. While not show quality paint, it is presentable.
The interrior looks like it is 32 years old, and needs to be re-done. The drivers side floor pan has a rust hole in it. No AC or Heat.
Other than that, things are in working order. The lights, blinkers, power windows etc. all work fine.
I bought it with the hope that my son and I can work on it together. We are very excitied to get started. Any advice on where to start and what to look for would be much appreciated.
I will be searching the archive and asking questions. I hope to see some of you guys on the road!
Rob
If you intend on driving it while working on it, always start with safety items:
Brakes
Tires
Front and rear Suspension
Exhaust
The rust hole in the floor is of consern, because water got there from somewhere, usually the t-tops leaking. I would check the birdcage (windshield frame) for rust. Pull the carpet and the kick panels out and check for additional rust on the body mounts. I have friend who has the same problem with '77, and he has no other rust problems. However, I would still check to make sure before you dump a lot of money into the project only to find you have a rust bucket.
This forum LOVES pictures, so please post some of your ride. Also, fill out your profile so people know what part of the country/world you are posting from.
Welcome to the forum and congrats on the new Vette.
Your question is one of the first that most of us ask when we get a new Vette and find this forum. I think the consensus is that you should first check the car over for safety. Verify brakes, steering components, wiring, etc. - anything that would make the car safer to drive. I would change all the fluids as soon as you get a chance which will also serve to help you get familiar with the car.
Then, some good advice that was given to me was to just drive the car for awhile and let it tell you what it needs. I did that and discovered a few things that were more important than what was on the list I was making.
Also, keep a look out for Bubba (look for improperly made repairs). You'll find his handy work everywhere.
Good luck with it. Show us some pics!
DC
OK- NOW YOUR'E DEPRESSED...SORRY. I guess my point is that one, it depends on what kind of vette you want- original vs. modified...then what you want to use it for (mine is dual purpose: cruiser/occasional drag racing), then put a plan on paper. I agree with the others- drive it a bit and it will tell you what it needs. Then break up problems with the car into projects- gather parts needed- then set a mild timeline- and get your son involved in the planning process. Have fun with it and good luck-DDBSTires
Exhaust
sgm2004
Welcome '76 brother. And enjoy all the fun ahead with your son next to you...
I just retired from the Army and since now I am not traveling all over the world and have a garage of my own, I look forward the project.
I will post pics soon. Keep the rubber on the road and and the T-Tops off!!!!!!
