headlight problem
Old Nov 24, 2008 | 07:11 PM
79dreamvette's Avatar
79dreamvette
7th Gear
Default headlight problem
i have a 79 vette with a 350. i just got it about two weeks ago. it drives great but the headlights didnt work so i can only drive it during the day. they popped up and down, but no light. i replaced the light swith and still no lights but when i replaced it my lights got stuck open. i kno i put the vacuum lines back on right because i labeled everything. i need some help. some vacuum line diagrams and some headlight switch diagrams would b a huge help.
Old Nov 25, 2008 | 01:04 AM
Peterbuilt's Avatar
Peterbuilt
Default Headlight Headache.
Hi and welcome to the forum and Congratulations on your first Vette!
Most electrical problems on a Vette are because of bad grounds. Pull the headlights and with the switch on, use a test light and probe the sockets that plug into the headlight. If you have a good ground on the test light and it lights than you know it a bad ground. If there is no power to the lights than work your way back to the dimmer switch.
The vacuum section:
Remove the vacuum hose on the small side of the check valve and run a jumper hose from that port of the check valve to the "T" on the top port of the relays, with the motor on the headlights should go down.
If they do than either the vacuum section of the switch or the pull down switch is bad.
The correct way to hook up the vacuum line is:
from small port on the check valve, thru the firewall, to the rear connection on the light switch.
Then the next hose goes from the front port on the headlight switch to the bottom port on the pull down switch.
Then the next hose goes from the top port of the pull down switch back thru the firewall and connects with a "T" to the top port of the relay valves. PG.
Old Nov 25, 2008 | 08:25 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by 79dreamvette
...they popped up and down, but no light...
Check headlight fuse; check headlight relay
...i replaced the light swith and still no lights but when i replaced it my lights got stuck open....
I'm guessing you hooked up the vacuum lines to the light switch backwards. The assembly instruction manual shows the routing. Override switch might also be open.
You can Google this diagram.
Old Nov 25, 2008 | 08:33 AM
...Roger...'s Avatar
...Roger...
Mike your killing me here....I been trying rid CF of this diagram because the hoses are connected wrong.I cant seem to get 101 to take notice and correct it.
Old Nov 25, 2008 | 09:02 AM
...Roger...
79dreamvette...Please follow this diagram to hook up your hoses,dont follow the AIM or the GM shop manual because they are not clear and some are incorrect.
On your headlight switch check the 12 red for power if you dont have power you either have a blown fusible link or the 4 wire connector at the back of the passenger head is not making connection.If you do have power on the 12 red at the switch then check the 14 yellow at the switch with the lights turned on.
Old Nov 25, 2008 | 10:04 PM
79dreamvette
7th Gear
Default you guys rock
yall were a huge help. i got my headlights to up and down again. as far as the lights themself working, thats a different story. but i finally got a good look at the female recieving end up under the dash and i noticed a wire missing and it was melted where the wire was supposed to be. i couldnt find the short so i ordered a new wiring harness from a c3 corvette parts depot. if that doesnt fix it i will definately be runnin back to you guys for some help.
Old Nov 26, 2008 | 11:02 AM
Easy Mike's Avatar
Easy Mike
I zapped the old one and stole your corrected copy. Still, it's blue to blue and white to white, right?
Old Nov 26, 2008 | 11:22 AM
...Roger...
Great...Thanks....yes blue dot on headlight switch to blue dot on pulldown bypass using a blue striped hose...same with the white providing the dots are still there and the new switches come with the dots at all.Some dont.
To headlight problem
