70 - 72 front grille restoration ?
I cleaned up the rough casting edges of my originals and then had them re-chromed.
I then masked up the front edges. Its quite easy to do by laying tape along the full lenght of each horizontal and vertical line. The corners are then cut in using a sharp x-acto blade.
The tape was then folded down the sides of each section to a ridge that is about 1/8" down. The excess tape was trimmed off with a sharp blade.
I then etch primed and as my car is far from original painted them in satin black.
Primoz (02-20-2022)
In a month or so I'll be changing my engine. When I do that I will try to restore the grilles using powder coat. There is one that kinda resembles chrome that I have used on some stuff for the engine compartment and looks pretty good to me. The powder coater says if I grit blast the parts he can fill the pits with his coating before the final coat.
I'll post process and pictures when done.
Be very careful if you powder coat any parts that are "pot metal"...which I believe those grilles are. Powder coated paint must be baked at a high temperature (over 300*F). Pot metal is a LOW melting point amalgum of various metals: lead, tin, etc, etc.
IF the oven temp is set higher than the melting point of pot-metal, you will end up with a puddle in the oven, rather than a nice, newly painted grille. Very expensive mistake.
Chrome plating aluminum requires an electro-conducting anodize plating first, then the traditional copper, nickel, chrome.
This is what Ive been told. If I'm wrong, I'd be glad to hear about it.
If the grilles are aluminum, there is no problem with powder coating them. Are they?
About 1200 degrees F. Aluminum is not a problem.
#33
I agree. I have been told they are an aluminum alloy, but I'm beginning to think it's an aluminum alloy that's of very poor quality. I have actually no real knowledge, except that my long time replater refused to replate them since he said there were aluminum.. He did polish them for me, and except for some pits, they looked very good.
#35
The grills I got with the front clip I bought have been powder coated. They`re not real shiney like chrome, but close enough that I plan to use them as they are.
I don`t know where, or how it was done, but they came through it in great shape.
#37
Melting point for pot metal is somewhere between 300 and 400 degrees F. Low enough that powder coating (and the following baking process) presents a significant risk to melting them.
#38
St. Jude Donor '13
I know this is past 45 days old, but didnt want to start a new thread for the exact same thing. Hopefully it won't get locked.
Has anyone determined what the actual color is on these front grilles? Gunmetal? Dark phosphate? Is this info in any NCRS books?
FWIW: Powder coat bakes at 400 degrees for approx 15-25 min.
EDIT: Nevermind. I seen that Alan 71 has come to the rescue again in a different thread.
Eastwood's Zinc Phosphate #10281Z
#39
R/H front grille
Just surfing the site and seen this from some time ago, you don't still have the front grille do you or know of one for sale Reasonably priced?
Larry
larry.schenk@yahoo.com
Larry
#40
