1969 Stingray VIN Number has 'G' not 'S'
#41
#42
The only reason for having a 'rusted-out' birdcage on a non-rusty frame is so someone could sell the car based on the VIN on the birdcage. No one would graft a rusted-out cage onto a good frame for any other reason. If a tree fell on the top and crushed the birdcage, the owner would only allow a replacement cage in reasonable condition to be grafted to his 'good' frame. The PO found his "mark".
#43
ACCORDING TO THIS INFORMATION THE LAST PARTS OF THE SERIAL NUMBER WOULD NOT BE CORRECT. THE LAST PART SHOULD START WITH A 7.
1968-1982 Corvette Identification Serial Numbers
Model Year Starting S/N Ending S/N
1969 194679S700001 194679S738762
#44
Here's a stupid question. What's the vin number on the registration
papers? Didn't anyone notice when you had the car transfered to your name. It has to show up on some computer at motor vehicle office.
Tony.
Tony.
#45
The VIN number on the title I got from the seller, is the same as the VIN number on my new title, which is the same as the VIN number on the windshield frame.
#46
1 Post
St. Jude Donor '09
This car is interesting. Have you posted this question to the NCRS? Also ask the vette pros. Such as AL Green I think I might be wrong on the last name and I don't have a Driveline catalog near me to make sure its right, Anyway if his name is wrong somone please correct me.
#47
The font is strange too. Look at the "1" and "3" on your VIN tags as compared to this example.
Different font. No Legs on the 1's and fuller lower 1/2 circle on the 3.
#48
Location: About 1100 miles from where I call home. Blue lives matter.
Received 5,321 Likes
#50
#52
Received 1,468 Likes
Cruise-In II Veteran
Did GM have an assembly plant (G) in Framingham?
Good luck CV. Clearing this up with the DMV could be a real nightmare.
#55
I knew someone out there would figure it out !!!! Now to find out when it happened (just for my own curiousity) and get the thing re-titled to the correct number. Thanks !
#57
#58
wow, if you have any close friends in law enforcement, I would have them run the vin from the engine/frame to see if it comes back clean. There is no way that vin plate is correct for that car. Good luck, I don't envy your position with this discovery.
Kelly
Kelly
#59
#60
13437 is a 2 dr. Chevelle 300. But the series starts with a 3
134379G300001
Your VIN sequence begins with a 1 and it should be a 7 for Corvette.
1. Wrong Assembly Plant. "G" S
2. Wrong Vin sequence starting number "1" 7
Whats the build date on the trim tag?
