454 Hood
Old Nov 2, 2009 | 03:35 PM
pemmbroke's Avatar
pemmbroke
6th Gear
Default 454 Hood
does anybody know if a 1974 454 hood has a higher hood center than a small block car hood
Old Nov 2, 2009 | 03:44 PM
Derrick Reynolds's Avatar
Derrick Reynolds
St. Jude Donor '13-'15, '17 thru '22
not being 100% sure what you mean by "higher hood center", I am going to go out on a limb and say "yes". The big block hood provides more vertical room under it than the small block hood, I forget what the clearance difference is, but I bet someone will know. It definitely looks higher from the driver's seat, but I wouldn't say it "impairs my view" at all.
Edit: Actually, that isn't true. From my comfortable sitting position, I can't see if the passenger's side headlight housing came up or not with my BB hood where I could with my SB hood. Luckily, my "headlight" warning light works, so I don't have to lean over to be sure
Old Nov 2, 2009 | 04:05 PM
pemmbroke's Avatar
pemmbroke
6th Gear
yes that is exactly it, thanks
Old Nov 2, 2009 | 04:52 PM
GD70's Avatar
GD70
I think they are the same except one says L-82, the other, 454.
Old Nov 2, 2009 | 05:11 PM
SteveG75's Avatar
SteveG75
In 1974, the hood was the same, big block or small block. Same hood from 1973 to 1975. The 1968-1972 BB hoods were taller than their SB equivalents but that is not what you are dealing with.
Old Nov 2, 2009 | 05:12 PM
SteveG75's Avatar
SteveG75
Correct answer for 1968-1972, wrong answer for 1974. All 1974 hoods are the same.
Old Nov 3, 2009 | 08:25 AM
Derrick Reynolds
Did not know that. Sorry.
Old Nov 3, 2009 | 08:35 AM
Ganey's Avatar
Ganey
74 has the same med. rise hood on SB & BB. Better clearance than the early hoods. The L-88 hi rise hood is only 7/8" higher than the 73-79 med. rise hood.
Old Nov 3, 2009 | 10:13 AM
zwede's Avatar
zwede
I measured 2" difference between 68-72 BB hood and L-88, so that would support Ganey's post above that the 73-79 hood has about 1" better clearance than the 68-72 BB hood.
To 454 Hood
