'76 Blower Motor
Old Dec 17, 2009 | 09:52 AM
SamsUglyVette's Avatar
SamsUglyVette
1st Gear
Default '76 Blower Motor
I am working on my friends 76 and for the life of my cannot figure out if this is normal or not.
The blower motor will run on low as soon as the inigtion is turned on. The speed switch is in the low position, the AC is set to off. I know the speed switch works because if I put the controls to AC normal or heat, I can adjust the temperature.
Is the always on normal.
Old Dec 17, 2009 | 02:00 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Yes, it's normal. For some model years, the fan comes on low at start up.
Old Dec 17, 2009 | 02:29 PM
BenUK's Avatar
BenUK
It's been two years since my '76 was in one piece, but I thought it had an 'Off' position for the blower motor. It's possible to stop the motor completely, even with the ignition on. I can't remember whether it's the small silver fan speed switch that does this or the main AC wheel controls.
Old Dec 17, 2009 | 03:55 PM
...Roger...'s Avatar
...Roger...
I believe you had to have the large wheel in off and the blower switch in off to stop the motor when the car was running.
Old Dec 17, 2009 | 04:08 PM
'75's Avatar
'75
My 75 will stop the blower when I put the left control wheel to the stop position regardless of the blower switch position.
Old Dec 17, 2009 | 07:20 PM
forvicjr's Avatar
forvicjr
The general done this to circulate fresh air through the car. iv also been told its a safty feature to evacuate c02 if an exaust leak is present..
To '76 Blower Motor
