outside door handles
Old Jan 28, 2010 | 09:39 PM
clayrwilliams's Avatar
clayrwilliams
8th Gear
Default outside door handles
I got a 77 and trying to get the outside door handles off so i can replace it. This is turning out to be quite a task. I cant seem to get the armature off it. Anybody know an easy way to do this?
I am also have a hard time getting the old seatbelts out of it. I got the passenger side ones out but am having a very hard time on the drivers side.
Old Jan 29, 2010 | 07:17 PM
enroberts's Avatar
enroberts
I had to use an impact gun to get my seatbelt bolts out. The handles will come out you just have to figure out the right way to twist and turn them. I had my door panels off and windows up when I did it. Word of caution: put painters/masking tape around the door handle to prevent scratching the paint!! Don't know if this helps at all but it's just my experience! -Neal
Old Jan 29, 2010 | 08:35 PM
Vetteaddiction's Avatar
Vetteaddiction
Seat belt bolts --
Soak them with PB Blaster for a few days. If you don't have an impact gun use a breaker bar, extension and a six point socket.
Chris
Old Jan 29, 2010 | 08:46 PM
doctorgene's Avatar
doctorgene
Yes Sir: Just remove the latch ***. screws, let it drop down, then you can take both nuts off and unhook linkage to handle, and reverse to reinstall . Don't unhook any linkage from latch ***. Have a great day. Gene
To outside door handles
