Hunting old school wheels....
#61
FWIW here - excusing the sidebar if the following might be redundant to the OP's main topic - the measured rim width most often cited by manufacturers for a given tire is that prescribed by the Tire & Rim Association's (TRA) formula for establishing uniform section width standards. Without belaboring the maths (which vary depending on whether a tire is considered to have a low or high aspect ratio), many mistake these specified rim widths as necessarily constituting recommendations for optimum tire/wheel fitments, or, worse, believe that any rim width within the acceptable range will result in the tire in question exhibiting the same performance characteristics.
Now back to our regular programming...
#62
So there are what rim and tire makers recommend and what customers decide to run,
What's your personal opinion the safe range of wheel for a 295 50 15 ?
What is the optimal rim for same tire?
#63
Received 1,722 Likes
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
Also, even though the TRA may say xxx size tire belongs on this rim, a lot of performance tires (Hoosier and Michelin are know for this) tend you build their tires much wider than the size should indicate. The Hoosier 275/35R18 I run is wider than a lot of other manufacturer's 295s or bigger, but legally have to comply with TRA.
#64
I have the TRA yearbook open at my desk currently. The "measured" rim width is 9.5" and the "approved" rim width range is 8-10.5". Design target section width is labeled as 309mm, or 12.17" with a mximum growth of the tire up to 321mm or 12.64". I would say you could safely run the tire up to 11.5-12" wide wheels.
#65
edit - Sorry if it appears that I'm copping out here, but tho one might well safely run a wider rim than TRA max widths with certain tires, I don't feel myself sufficiently qualified to speculate as to where beyond that point to draw the line in general for anyone's use other than possibly for my own. And, while I may at times adamantly debate those who believe "balloon" fitments have no downside, I'm somewhat less inclined to do here.
#66
Bats... at the risk of being crass and also guilty of responding to an old thread...
Ya' just gotta look in the right place... such as the recycle yard where i dropped off the turbines.
Hope it all worked out all those years ago...
Carl
PS... old school pic from 2000 with one of those early digi cams...
Carl
#67
I could have bought what your looking for bats. A co worker had them. AZ wheels too. No rust whatsoever. That was a few yrs back and there gone now. Truthfully, some of todays modern cragars are not very expensive. You can get them in 17" which gives you the option to use a better rubber. Im looking to see if Cragar can build me an 18x10 in a 4.5" backset. 1 pc polished aluminum. I want to go to a larger rear for the offset look. the 17 x 8" were only $175 a pc.
#68
Halibrand wheels
You might want to look at the Halibrand wheels which were often used on Corvettes in the 60's. There is a great reproduction wheel from Real Rodders. Check it out. http://www.realrodderswheels.biz/
They were originally copied for Studebaker Avantis, but are correct and for and are available for Corvettes as well.
I had no idea finding what I call old school wheels would be like finding teeth in a chicken.
I guess it doesn't help that I do not really know for sure what style I want, I have never been all that jazzed up over wheels and several do look cool to me, like Slots, Turbines, and even the Cragar big spoke wire pimp wheels but I have never seen any that didn't have rust around the spokes,
The other thing is I want 15x10 for the rear 15x8 for the front seems most sets are all 8" wide.
I look on Craigslist and Fleabay but it seems every wheel on there is the newer taller import looking stuff,
I posted on here in parts but it's in with my ad for the rallys and redlines I have for sale so perhaps my "wanted" part is getting lost.
Are old school/used wheels just getting really hard to find?
I do not know where to look now, but hey if you have a set of wheels you don't dig hit me up....
