1977 Turn Signal Lever Lettering
Can someone in the warm climates (I just finished shoveling my driveway here in Michigan for the last hour!), take a picture of the lettering on the dimmer/wash-wipe/turn signal lever on a 1977 Corvette steering column. It is a one year only part. Also, it would be a real help if you people could supply a picture of the lettering on the T&T lever as well as the lettering on the standard (non-adjustable) lever.
Thank you in advance,
At least the economy in Michigan is so bad, I no longer have to worry about a snowplow coming by and filling the foot of my driveway.
Jim
Jim
Ganey - can you show/tell me how you moved your wiper function to the dash? This might be good to know if my turn signal lever breaks (knock on wood). No one sells a repro lever for a '77 T&T column...
The 1977 T&T wash/wipe lever is still available.
http://www.zip-corvette.com/ProductDetails/ProductDetails.aspx?pid={07af4a13-ca74-4218-82ff-450b436dc24d}&gid={22c9b1f5-2f38-4f92-956b-acbcde9be3f9}&GroupName=Turn+Signal+Comp onents&pname=77+Steering+Column+Wiper%2f Washer+Lever&Referer=&Alias=&ptct=SGR-SR&CTitle=&
At least it is still listed on the Zip website. Only $19.50.
The lettering on the lever is not identical to the original however.
Jim
Jim
The Corvette 77 wiper wiring has a connector that allows disconnect from the switch wiring in column. I used a 2 speed wiper switch w/ wash & installed at bottom left of dash near the factory connector. Easy.
Jim
Jim
Cruising
Browsing thru the forum and seeing you did EXACTLY what I want to do :-) I have a problem with the wiper lever on my '77 and want to install a switch on the dashboard, like you...
can you give me more details please..
Leonard (Bellgium) (leonard.liesens@gmail.com)
